Oil fliter question
Old Oct 19, 2006 | 05:22 PM
ForNgoods's Avatar
Default Oil fliter question
well i've always used fram and never had a problem but this is my first oil change in my S and i'm a little puzzled after comparing my OEM oil fliter to that of the fram one i purchased. When i first saw it i said to myself damn it looks kinda small. This cant be the right one but the guide at autozone say's it's the correct size (TG6607). when i bought it up to the checkout i again questioned the person behind the counter and she looked it up and reconfirmed that it was the proper size. Now that i'm in the middle of my oil change i'm begining to see that there are vast differences in the sizes of the two filters. The fram one is smaller in diameter and length compared to my stock one and i'm concerned whether or not i should even use it or jus go to honda and buy an OEM one. Can someone chime in w/ some insight???
Thanks
Khang
Old Oct 19, 2006 | 05:41 PM
S2kracka's Avatar
DO NOT ever use a Fram filter on a car that you actually care about. Spend the extra $2-3 for the good Honda PCX filter.
Old Oct 19, 2006 | 05:52 PM
WolfInSheepsClothing's Avatar
If it's smaller in diameter, then you probably have the incorrect filter. Fram filters are shorter in length than the OEM ones, but have the same diameter (they have to be the same because the seal needs to sit properly on the oil cooler)
Old Oct 20, 2006 | 12:29 AM
RACER's Avatar
[QUOTE=WolfInSheepsClothing,Oct 19 2006, 06:52 PM]If it's smaller in diameter, then you probably have the incorrect filter.
RACER's Avatar
Old Oct 20, 2006 | 12:50 AM
RACER's Avatar
Everything you always wanted to know about oil filters but were afraid to ask
http://forums.s2ki.com/forums/index.php?showtopic=192750
https://www.s2ki.com/forums/index.ph...opic=150531&hl
https://www.s2ki.com/forums/index.php?showtopic=189310
Old Oct 20, 2006 | 12:58 AM
jonathanschley's Avatar
Originally Posted by RACER,Oct 20 2006, 12:29 AM
Not necessarily true. The outer diameter's of these filters can vary while the contact area remains identical.
exactly... the HAMP filter is way smaller diameter than the OEM Honda one.
Old Oct 20, 2006 | 06:41 AM
gomarlins3's Avatar
I have used Fram 6607 since my first oil change 4 years ago with no problems. I have used Fram filters on all of my cars for over 23 years with no problems. I am not saying they are the best, I am only stating actual facts.
Old Oct 20, 2006 | 06:58 AM
SpitfireS's Avatar
Honda has an oil filter especially for the S2000.
For a reason I guess.
If you "go by the Honda Owners Manual Bible" to make your decision about engine oil.. then why not for the PCX filter as well?
Silver5656
Jun 18, 2008 06:12 PM
dan_uk
Apr 24, 2008 05:13 PM
Marrk
Apr 27, 2007 08:16 AM
-=Theoscion=-
Oct 20, 2006 08:33 AM
asukadc
Mar 17, 2006 09:25 AM
