oil pressure/ tct
Old Jun 2, 2008 | 09:44 AM
skeithr's Avatar
Default oil pressure/ tct
the tct in my 02' is going out, i got an oil change and the clicking went away, that was about 1,000 miles ago, my ? is how long can it last with good oil pressure, the only time it clicks is on a hot start up for about a sec. then the sound goes away, im currently in a financial bind and was wondering if the tct will hold out for a couple more weeks. any feedback will be greatly appreciated
Old Jun 2, 2008 | 09:54 AM
Hockey's Avatar
Well I'd hate to give you advice and have things go wrong, so you'll really have to decide if your gonna drive on it.
Personally, I put up with the rattle (at cold start-up) for months before I finally discovered the cause by stumbling upon discussions here on this site. That was a long time ago and I have replaced numerous ones in local S2Ks. Mine was only needed once - knock on wood.
I'd say drive on it. Keep an eye your oil level. Replace it when you can.
-Hockey
Old Jun 2, 2008 | 11:51 AM
skeithr's Avatar
thanks for the reply, still kindof worried but that does make me feel alot better, i noticed the noise when it started a couple of weeks ago, have only had my car for 6 wks.
Old Jun 2, 2008 | 12:09 PM
daktruckie99's Avatar
I drove with a bad TCT for 10k because I did not know what the noise was!
It will get worse as the oil level drops so keep the level where it belongs and you should be fine for a few weeks.
Old Jun 2, 2008 | 01:06 PM
Hockey's Avatar
Here is the link I promised....
TCT DIY
-Hockey
Old Jun 3, 2008 | 09:52 AM
skeithr's Avatar
can i kick it into vtec or do you guys think it would be best to stay out of it till it gets fixed
Old Jun 3, 2008 | 09:53 AM
skeithr's Avatar
also is there a guide to show how to do it floating around here or do i need to go invest in a helms guide
Old Jun 3, 2008 | 10:11 PM
skeithr's Avatar
any response would help
Old Jun 4, 2008 | 03:17 AM
I spent plenty of time in VTEC with my bad TCT, again it was because I was unsure of the problem and did not change my driving habits one second.
In fact, with a bad TCT it only produces poor tension at idle. So in theory as the revs climb it's still doing it's job.
As for how to replace it, many write-ups on the board. It is quite simple and the helms doesn't even talk about it actually. Helms book details how to remove and re-install the same one which is a different procedure than installing a new one.
JayJones
May 18, 2015 08:12 PM
Northernsky
Oct 18, 2011 02:25 PM
MBHs2k
Mar 6, 2010 07:57 PM
machviper9
May 6, 2007 11:14 AM
Jonsey Boy!
Feb 11, 2007 08:15 AM
