Oil Stabilizer
Old Nov 29, 2011 | 10:30 PM
SpitfireS's Avatar
Originally Posted by slipstream444
Amsoil ATM 10W30 actually specs out more like a 5W30, but they have kept it a 10W30 in order to fill a marketing slot,
Who put this stupid idea in your head?
I mean...
A quality synthetic does not require "stabilizers".
100% true
Some info about viscosity: water, you know, H2O, has a viscosity of 1 cSt at 20c at sea level - a standard science condition
(just forget about the cSt, its no more than a unit)
As far as I know they actually used water as the reference back in the day when they were figuring out about viscosities.
2 cSt is twice as thick, IOW its a linear unit.
10W-30, when hot, is usually around 10 cSt, so 10 times thicker than water and that is HOW IT SHOULD be.
A hot 5W-40 oil is around 13 cSt, you will notice the difference pouring out your hot engine.
Old Nov 30, 2011 | 03:56 AM
zeroptzero's Avatar
Good info. , on the 40 weight I used it sheared down to 11.4 cst, not uncommon in some 40 weight brands/weights, so when it came out hot it was hard to distinguish much of a difference from it and an unsheared or mildly sheared 30 weight. Perhaps if you rubbed it between your fingers, but visually from sitting under a vehicle it doesn't look much different.
Old Nov 30, 2011 | 09:07 AM
SgtB's Avatar
At that point it's all about it's sheer strength. It can appear runny at temp, but still hold the surfaces apart from each other which is mainly what it's trying to do.
chriss2kk
Apr 10, 2013 10:56 PM
NoHander
Oct 17, 2011 09:58 PM
busbus
Feb 10, 2011 02:41 AM
navybeaN
Jul 15, 2003 08:04 PM
demonderrick
Jul 16, 2001 08:47 PM
