Is our TPS adjustable or can I get another TPS?
Old Nov 20, 2006 | 02:47 PM
S2KAZ's Avatar
Default Is our TPS adjustable or can I get another TPS?
I believe I need a new TPS and don't think the one on our car is adjustable. Is it? Or do I just need to somehow remove the factory screws, adjust it and put removable screws? Any help will be appreciated.
Old Nov 20, 2006 | 03:32 PM
Slows2k's Avatar
The factory screws are tamperproof, and you have to cut the head off to remove them. Even so, you can't buy a TPS sensor on it's own.
Why do you think your current TPS is faulty?
Old Nov 20, 2006 | 04:55 PM
S2KAZ's Avatar
My idle fluctuates from 1.5k to 1.7k. I went to Autozone so they can read the codes and it gave 3 different codes, MAP(P0108), TPS(P0122) and Intake Man. runner control(P1519). First I tought is was a MAP problem, but after putting a new one nothing changed. So I just took a look at the TPS and the input is a solid 5V but the output is .23V when the tb is close and 4.7V when fully open. To my understanding that is a bit low. Hopefully I'm in the rigth path. Let me know what you think.
Old Nov 20, 2006 | 05:57 PM
Slows2k's Avatar
Autozone incorrectly defined the P1519. It's IAC electrical malfunction, not Intake manifold runner control. (which no S2k has ever had)
Chances are you've got a faulty IAC. Which DTC recodes?
Old Nov 20, 2006 | 06:34 PM
S2KAZ's Avatar
Where in the IM is the IAC at and how do I test it? I keep getting 0-3, 0-7, 1-0, 1-4. Thanks for the help.
Old Nov 20, 2006 | 07:04 PM
Slows2k's Avatar
Sorry, I don't keep up with flash codes. The IAC is bolted to the manifold behind the throttle body.
Old Nov 26, 2006 | 06:42 AM
S2KAZ's Avatar
Just want to say that Slows2k was right on the money. I swap IAC and is been working fine for 2 days. Thanks again for the help.
Old Nov 26, 2006 | 07:31 AM
Slows2k's Avatar
Old Nov 26, 2006 | 09:53 AM
b00stn's Avatar
What's happening? Uh... we have sort of a problem here. Yeah. You apparently didn't put one of the new cover sheets on your TPS reports.
DxC
Mar 21, 2015 07:04 PM
mrchavez723
Jul 9, 2014 07:16 AM
s2kseven
May 21, 2012 10:19 AM
ChefJ
Jan 23, 2009 07:28 PM
maluch
Jul 1, 2008 10:26 AM
