P0107 MAP low voltage help
Hello, my 2000 s2000 recently threw out p0107 code. If I drive the car for 15+ minutes when coming to a stop (idle) the rpm’s drop below 800 and car begins to shake and hesitate wants to stall but won’t. I turn off the car for 5min turn it back on and it is back to normal. No power loss drives smooth. I replaced my map sensor with a Honda OEM but no luck.(did a map wack too) I also took it to a shop they found no electrical power issue all volts are what they should be. They also did a smoke test and found no leaks. They couldn’t figure it out. Also did the zip tie trick for the MAP and no luck.
car is completely stock 145k miles. Thanks
Hello, I just bought a Honda S2000 sadly it had a odometer rollback so I was scammed, odometer reads at 130,000 miles but came to realize car actually had over 300,000 miles.
What fuel are you running? (Grasping at straws...)
-- Chuck
hello, yeah same car i run standard 91 from shell. I only drive the car on weekends and have never had an issue
idle surge site:www.s2ki.com
-- Chuck
When I got the low map signal CEL my car wouldn't even turn on, and if it did it would stay in limp mode. Replacing the MAP sensor fixed that issue, although it may have been related to the main fuel pump relay, as several sensors are tied into that relay. Fun fact you can get a MAP based CEL for abnormal vacuum if your gas cap is left loose.
-- Chuck
Hey guys, did another small check. When the car is idling rough, if I unplug the sensor the idle doesn’t change at all. What can this mean? Connecting pigtail is bad or is it possible Honda sold me a bad MAP sensor?
Do you get a CEL when you unplug it? Have you checked the main fuel pump relay for any deteriorated solder joints? The Idle air controller, the water temp gauge, fuel pump, and some other sensors pass through that relay so it can affect idle quality.
I’ve tried everything that I’m comfortable doing with my car, but no issue found or fix. I will be taking the car to Honda tomorrow. I’ll update everyone with what the problem was according to Honda.
Nate03
May 9, 2004 03:24 PM
