p0420 cel
I got the CEL the day after I bought it. I got it reset just to see if maybe it wouldn't come back but it did.
My AutoZone printout reads:
Definition-
Catalyst efficiency low bank 1
Explanation-
The oxygen sensors monitor the catalytic converters ability to store oxygen.
Probable Causes
1. Catalytic converter defective (failure possibly due to #2, 3 or 4)
2. Engine misfire or running condition
3. Large vacuum leak
4. Engine oil leage into exhaust valve guide seals, piston rings.
Now number two, to me, looks like maybe I could take these Bosche spark plugs out (that were included with the purchase), and install the OEM which will be in tonight. Other than that I looked for large vacuum leaks and saw nothing. So does anybody have an idea? Maybe somebody out there has dealt with this. Thank you.
Definition-
Explanation-
Probable Causes
Maybe just the O2 sensor along with the CAT. Many have had the problem and the cat has been revised in later models... here is one of a number of threads.
https://www.s2ki.com/forums/index.php?showt...0&#entry6015677
