P0497 Check Engine Light
Old Mar 9, 2018 | 01:39 PM
runyonwc's Avatar
Default P0497 Check Engine Light
Hello,
I just bought a 2005 S2000 on Tuesday and today the check engine light came on. The code Advance Auto pulled is P0497 Evaporative Emission System Low Purge Flow. I did a search and some mentioned replacing a purge solenoid, where is that? Is there anything else I should look into? The car is running fine. I'm new to S2000s so I don't know where these items are located.
Thanks for any help
Old Mar 16, 2018 | 03:24 AM
runyonwc's Avatar
I'm still having issues with this P0497 code. I replaced the purge valve solenoid yesterday and the check engine light came on again this morning. Any ideas where to look next? New Gas cap? Maybe change the fuel tank pressure sensor?
Old Mar 16, 2018 | 04:54 AM
dakao's Avatar
Might be your evap canister, I would get used one on ebay
Old Jul 30, 2019 | 08:51 AM
esalcedo's Avatar
Did you ever figure out what the issue was? I have the same code, so far i have checked for blockages and the purge valve and all seems fine.
jakejjang89
15
Mar 17, 2010 11:27 AM
photog72
Aug 25, 2007 05:19 PM
DannyInKorea
Feb 16, 2006 09:32 AM
smanders
Nov 22, 2002 11:21 PM
turbomadness
Feb 18, 2002 11:05 AM
