P1259 problem..
Old Apr 17, 2006 | 01:54 PM
darkfx's Avatar
Default P1259 problem..
I know its a VTEC issue.. but what exactly is it? rev limiter is at about 7k but it still feels like vtec is actually kicking in.. i cleared the code, it hasnt come back but the rev limiter is still there...
It happened while in a interstate, about 70mph, dropped it into 3rd at about 6500rpm, tried to take it to redline, but the car just totally cut out at 8k rpm.
Old Apr 17, 2006 | 02:05 PM
xviper's Avatar
"A problem in the VTEC oil pressure switch circuit or VTEC solenoid valve circuit."
Check oil level. Check oil pressure. Check wiring harnesses at the VTEC solenoid and pressure switch. The rest of the checks are more detailed and involves reading voltages.
Old Apr 17, 2006 | 02:34 PM
darkfx's Avatar
everything seems fine.. time to take it to a shop?
Old Apr 17, 2006 | 02:49 PM
xviper's Avatar
If you're sure about all these points, then yes.
Old Apr 17, 2006 | 02:52 PM
darkfx's Avatar
ok, thanks for your knowledge, xviper
Old Apr 18, 2006 | 07:32 AM
Wisconsin S2k's Avatar
https://www.s2ki.com/forums/index.php?showtopic=378792
Unbelievable how someone can just clear a CEL thinking it will go away and fix the problem.
Old Apr 18, 2006 | 07:59 AM
stitos2k's Avatar
And that's all I'm saying on the subject.
TvoS2K
Nov 21, 2017 03:18 PM
Tmorrison
Aug 12, 2017 02:35 PM
L11KOY
Feb 17, 2015 10:14 PM
stockport_lad
Apr 15, 2002 12:32 PM
