PGM FI Main Relay Failure?
Old Jun 21, 2021 | 12:39 PM
RolanTHUNDER's Avatar
Default PGM FI Main Relay Failure?
If you have a SOS wiring kit powering an AEM 340 LPH pump, can the main/fuel relay fail under the voltage requirements?
I ask because I'm troubleshooting a start then 2 seconds later switch off problem. If that relay is bad (or any relay like ignition) will the fuel pump even prime or will the car even start?
Old Jun 29, 2021 | 01:45 AM
SOLVED - the issue was caused by a stuck open VTEC solenoid I swapped in recently. Went back to original and the problem disappeared
Old Jun 29, 2021 | 06:18 AM
boyguan's Avatar
and how did you discover this?
just reverse of what you installed?
Old Jun 30, 2021 | 09:54 AM
When I recorded a video for my friend at the end of it I said "it sounds like a race car with very aggressive cams...". That was the clincher
I then decided to do a little research first to see if the solenoid can actually fail or malfunction like that. I found such info. I then went to disconnect the solenoid but leave it on the head. Tried to start and the problem persisted. Then I removed the solenoid. That's when I saw the difference between it and my original one.
landapanda
Jun 21, 2021 02:47 PM
umair
Jul 19, 2015 06:05 PM
LordSovereign
May 27, 2015 12:30 PM
abumchuck
Dec 15, 2011 05:27 PM
GDM S2K
Jan 8, 2007 08:48 AM
