PLEASE HELP! Need advise after botched head resurfacing job
Silver_Bullet_S. Just out of curiosity, what was the event that created the need for milling both head and block?
Thanks!
Thanks!
So sorry to hear about all your troubles. Life hit you with a lot all at once. Kudos to you for standing back up and moving forward after taking such hits that would keep a lesser man down.
Billman should answer about use your aftermarket valve train or oem.
Small claims limits are often quite long. Google for your state what the limits are. Maybe you could still file for shop two.
I tried searching the forums for a head but no luck. I see AP1 heads on ebay ranging from $850 - $1500 which is a lot of money (the heads aren't even complete), but how would I know if the head is in good condition if I cant see the head before purchasing it? I don't want to end up w another useless head & Ebay seems very risky to spend that much money w/ no guarantee.
Also, since I have a 2006 S2K, it makes finding a head harder becasue I don't have the air pump & AP1 heads have the air passages for the air pump. I heard you can plug them by getting them welded, but that just leaves another area where something can go wrong & you can see what my luck I've had w/ machine shops already.
How do people who need a head for their S2K go about securing one? Are there any used motor shops/distributors known for having heads? Do I have to find another 2006 head, or is is not too complicated to make any 2000-2005 head work? Any advice from anyone is appreciated.
Billman if you're out there & have any tips, I'd certainly be very grateful.
The car is in pristine condition otherwise, not a dent or scratch. The block was rebuilt with new OEM rings & bearings, new clutch, etc. The head is the only issue.
Do you have any advice on how to find a head, preferably a 2006+ cyl head? I'll take an AP1 if i can find one that's unmilled, but worried about the complications of plugging the air pump passageways.
The bottom end parts looked fine but I had it torn down to be cleaned, straightened, and replaced the rings & bearings & clutch. The crank, rods, and pistons were in great shape.
Know anyone with a head to sell or where to get one?
jyeung528
51
05-26-2009 11:19 AM
