Pops out of 2nd gear, need help quick!
Old Feb 3, 2009 | 03:08 PM
houstonpv's Avatar
Thumbs up Pops out of 2nd gear, need help quick!
Okay, I need more input on this matter. If you have a MY04 please do not comment on your 4th gear problems, unless they can be specifically related to mine with some details please... as there is a TSB for that year but not for MY01. (I cant just show up with a peice of paper and say fix this) Thanks.
OK
My 2001 is popping out of 2nd gear. It happens randomly. From a dead stop I will go from 1st to 2nd with no problem, then engage the clutch fully and drive... a few seconds later, sometimes immediately, the clutch is violently thrown from 2nd to neutral with a loud "THUD".
It has done this for a very long time, im very annoyed with it and need to get it fixed. All my other gears, 1,-,3,4,5,6 are PERFECT! they are smooth and I have absolutely no grinds. This is only affecting 2nd gear.
I have been told to "replace the tranny", but Im looking for something a little more specific. like, what is wrong with it? what parts could be broken? Please, if anyone has helpful insight to this then post it up! Also, Im way out of warranty. What kind of costs are associated with this kind of work?
Old Feb 3, 2009 | 06:15 PM
houstonpv's Avatar
Old Feb 3, 2009 | 07:44 PM
ahrmike's Avatar
Sorry man, Idk. I cant imagine why if the gear was engaged properly, why it would pop out unless you were:
1) accelerating
2) Deaccelerating.
if youre just cruising along, nothing should happen. You're 100% sure its totally in gear?
Old Feb 3, 2009 | 08:35 PM
houstonpv's Avatar
1) accelerating
2) Deaccelerating.
200% sure its in gear. but its usually on accelleration... as I am going through the gears. like normal driving. If I try to downshift, it will do the same thing.
AutoX is next to impossible.
Old Feb 3, 2009 | 11:22 PM
ahrmike's Avatar
Sorry, I dont profess to be a transmission expert and Im not entirely sure but I think if I ask the right questions someone may understand what the problem is.
if its on acceleration, does it happen as you shift, let up the clutch, press the gas drives a while THEN pops out as you hold the gas down?
or does it pop out as soon as you stop holding it into 2nd gear?
IF I understand a transmission correctly, that sounds like your gear itself is stripped, so when it clicks over to the gear, theres no meshing, its more of a kicking out of gear?
Idk, its best to probably eithier get a used one if you can, for cheap...but if you cant, go try get a mechanic to take it apart + upgrade some parts while youre at it.
Old Feb 4, 2009 | 06:15 AM
houstonpv's Avatar
thats right. After I shift into 2nd and the clutch is fully engaged, I will drive for a few seconds and then it will pop out. I have made absolutely sure that the gear was in all the way.
Old Feb 4, 2009 | 07:13 AM
GrandMasterKhan's Avatar
I had a similar issue. It ended up being a TSB from the toleraces in the tranny being too tight or too loose. I dont know if thats your issue but I had an 04.
Upon further inspection it turned out that a shifter fork was bent, the final drive gear was chipped. I feel this was due to putting it back into gear immediatly after it popped out which would cause a violent grind.
You may be able to rebuild the tranny. But in my expeirance a rebuild ended up making it worse and made it happen in other gears too.
Old Feb 5, 2009 | 07:08 PM
houstonpv's Avatar
still looking for other ideas as to what is goin on.. i may havea pretty good idea, but would like your input!
cat5cable
Jul 25, 2012 04:06 AM
arkui0129
May 20, 2009 03:31 PM
houstonpv
Feb 3, 2009 06:28 PM
StockSH
Jul 27, 2004 12:28 PM
redleader
Mar 13, 2001 04:22 AM
