Possible causes for CEL?
Old May 14, 2003 | 07:16 PM
docofmind's Avatar
Default Possible causes for CEL?
While driving home from work today in relatively slow city traffic, my CEL turned on. I quickly pulled over, checked for oil leaks (recent oil change) and took a quick listen to the motor. Everything checked out ok. Got back in drove home and everything seems fine. No loss in power, no wierd noises, no weird feel.
Just wondering what you guys think could possible cause the light to come on. I remember my buddies CEL came on in an older car due to a bad 02 sensor but i highly doubt thats the case. Car has only 28k on the clock.
TIA
Old May 14, 2003 | 07:39 PM
TepEvan's Avatar
gas cap or oil cap not tight enough issue??
Old May 14, 2003 | 09:40 PM
ChrisD's Avatar
While you did check for oil leaks, did you actually check the oil level?
You may also want to check all the vacuum and coolant lines (the black hoses connected to random places to the block and intake). A leaking hose or connection can cause the CEL to come on.
Worst comes to worst, bring it back to the dealer. Usually checking the code is within warranty. Just make sure that they don't do the actual work until you've approved it: We went to a dealer once with a CEL, they checked it (which was within warranty) and plugged the hose back in (which was not within warranty). They charged us 75 bucks for the plugging the hose back in, something we could have easily done ourselves, had we known the problem. We managed to talk them out of it (since they never cleared the 30 seconds of "labor" with us before doing it) but you want to be sure, in advance, of what you're getting into.
Old May 15, 2003 | 05:45 AM
Gernby's Avatar
Former Sponsor
Autozone will pull the diagnostic code for you for free. There are too many things that it could be (gas cap, spark plug, injector, coil ...).
Old May 15, 2003 | 09:24 AM
docofmind's Avatar
Thanks guy, I ll double check all of them again.
If i reset the ECU and the light doesnt come back, can i still do the diagnostic thing or will the code that was thrown be erased as well?
Thanks again
Old May 15, 2003 | 10:07 AM
xviper's Avatar
[QUOTE]Originally posted by docofmind
[B]Thanks guy,
Rollinx25
Dec 23, 2007 05:58 PM
Pointman15
Oct 26, 2007 12:37 PM
ej3ffrey
Jul 22, 2006 03:30 PM
slps2k
Jul 28, 2005 02:44 AM
mjudson
Dec 22, 2003 12:15 PM
