POWER LOSE
Old May 9, 2007 | 08:35 AM
  #31
jyeung528's Avatar
if you're getting good compression, you shouldn't need a leakdown test.
BUT...i highly doubt the results of your compression test if you're feeling "power loss" without any other problems.
leakdown is more foolproof, costs about 45 bucks. have a mechanic do it...
Old May 9, 2007 | 08:43 AM
  #32
iDomN8U's Avatar
Weather could have played a part, the hotter it gets I would imagine it would pull the timing
Reset the ECU
Second idea: Bad gas, which will also result in the ecu pulling the timing
Reset the ECU
Third idea: Get a Dyno run in, it will speak for itself
Old May 9, 2007 | 10:52 AM
  #33
SpitfireS's Avatar
verviers Posted: May 8 2007, 03:01 AM
No engine light on. New Oil. Basically the car no longer has the KICK
What kind of oil? 20W-50?
I'll second iDomN8U second idea: bad gas.
Put the OEM sparkplugs back in.
Give the MAP a Wack.
Long shot: one of the cat's cores has broken into pieces and is blocking the exhaust. Any rattle from down there?
Allthough the metal foil cores don't break up like ceramic cores may.
Btw.. the OEM clutch is pretty good.
Only if you go FI you may really need a stronger PP.
If you can't recognize a slipping clutch and think it is "Loss of torque" ....
Old May 9, 2007 | 12:20 PM
  #34
ChuckV's Avatar
If your shifts suddenly feel "smoother" than maybe your clutch is slipping... Have you done the clutch test yet? Another way to test is going up a steep uphill, mash the gas, if the RPMs go up but the car doesn't move, you have a slipping clutch. Best done close to peak torque.
Old May 9, 2007 | 03:02 PM
  #35
verviers's Avatar
Got pleanty to do now, thank for the help, I'll post as I test...
Old May 9, 2007 | 03:15 PM
  #36
Mr. Eryozgatliyan's Avatar
Banned
I bet your just used to your car, that's all.
When I first got this car, I thought is was so fast, I couldn't even go to red line without thinking I was driving like a mad man. Now, I think the thing is a slug
Old May 9, 2007 | 06:15 PM
  #37
R3DS2K's Avatar
i know i asked before.. but what was done right before it felt like you had a power lost.. even the smallest things. got gas.. weather changed.. nail in tire.. got new tires.. brake job.. anything.. small to big.. that could affect or not affect your car.. its odd.. that it was just all of a sudden..
Old May 11, 2007 | 10:30 PM
  #38
verviers's Avatar
No, I never really thought that S2000s were fast, sorry guys I sell Audi's I think the new 3.2 TT is faster, so is my old 2.7 Bosxter, RS4, S4, s6, and a crap load of others. I do know that the S2000 is quicker than all of them (maybe not the RS4). The shit is driving me crazy, I'm not the only butt dyno around that notived with, 3 people whom know my car did... I'll keep you all updates.
Old May 12, 2007 | 08:43 AM
  #39
R3DS2K's Avatar
how bout a video.. your not giving use much info about your car
Old May 12, 2007 | 10:42 AM
  #40
kill's Avatar
Originally Posted by Billman250,May 7 2007, 08:35 PM
Next thing I'd do is put the stock spark plugs back in.
lol seriously...why do people think these $20 dollar each spark plugs do anything? its been basically proven that they can actually do more harm than good in basically any application that wasn't designed for it. honda designed the engine to use the spark plugs it came with. if it was designed to put in 4 and 8 pronged insect lookin spark plugs they would have from the factory if they were "so damn good"...there not..don't waste your money..and don't let yourself be fooled.
the only place those spark plugs are good in is applications that are designed from the start to use spark plugs with that many prongs.
and no your piston or valve will not break off the prongs...its caused by heat/wear..and its basic common sense...if you have 4 failure points instead of 1 you have a 400% more chance of failing...you can't argue with this logic like you can with "people on the internet telling me they're bad"...also billman basically specializes in fixing s2k's...anytime he says something you should listen and take note.
the reason i know to use only oem spark plugs is because my step dad is a shop foreman of a local diesel shop...he's on the curriculum board for the local vo-tech mechanic program and basically has final say if students pass or not. he has over 25 years of experience in engines...when he says i shouldn't be fooled by "advertising gimmicks" like "oh it has more prongs it must be better!!!" then i'm not gonna be fooled...also if they were so good all cars would COME WITH THEM.
another reason...my uncle who is an ASE master certified technician who's also worked at one of the top local dealerships for over 20 years has said the same exact thing about the spark plugs...waste of money and it has the chance to destroy your engine because its just not made for that application.
you don't have to listen to "people telling you how it is on the internet" if you don't want to. but i'll always know the truth and the people like me will always look at you and say..come on man..we're just trying to help and some of us know a shit load more than you...and i'm not talking about myself.
