Power steering issues!
Old Jan 6, 2012 | 08:08 AM
  #61
SgtB's Avatar
OBDII port.
Old Jan 27, 2012 | 11:26 AM
  #62
RobinA3's Avatar
I am looking at resetting my eps, looking at my obd port I don't have a wire in pin 9. Anyone know why this is?
Old Mar 1, 2012 | 08:47 PM
  #63
silverstoneds2k's Avatar
You guys I'm still having the problem no eps I'm taking it to the dealer Monday. If its outrageous price to fix I'm selling her this no power steering is really bad
Old Mar 7, 2012 | 11:05 AM
  #64
Got my power steering fixed guys finally!!!! Do not try to diagnose the problem by replacing parts i repeat do not do it or take to a mechanic other than honda to diagnose they wont be able to without the honda computer thing. My eps system just had to be reset took it to my buddy who works at honda 15 mins later problem solved!!! If you are having problems with eps take it to honda they are the only ones who can diagnose and fix it no 1 else can i repeat no 1 else can. I bet all you guys that are having problems just need to get your eps reset by honda just bite the bullet take to honda that is experienced with s2k. trust me i have been driving with no eps for almost 2 years which pisses me off because it was a easy fix
Old Mar 7, 2012 | 11:09 AM
  #65
If you guys have any ?s pm me i will do whatever it takes to help you guys because i know how bad no eps is
Old Mar 7, 2012 | 11:11 AM
  #66
D_Spec's Avatar
I will try this. Thanks. Did you have the light? Or just no PS? I never had the light come on.
Old Mar 7, 2012 | 11:34 AM
  #67
My light never came on because the bulb was burnt out. If the eps and cruise control light dont light up when you turn on ignition its the bulb. If you do take to honda tell them you just need the eps reset and torque sensor neutral position memorized. If your eps used to work like mine did the eps needs to be reset and neutral position memorized or theres a short in the wires those are the only 2 problems it could be. I hope you get it fixed i feel your pain bro
Old Mar 8, 2012 | 08:32 AM
  #68
PENROD's Avatar
Silverstoned,
did you have the problem in warm and cold weather (below 70) or all the time?
Mine was only having issues in colder conditions. In Florida Summer, I would have no issues. That sounds typical of alot of the complaints here.
Old Mar 9, 2012 | 07:36 AM
  #69
I had this problem all the time cold weather or not. I do live in so cal doesn't get below 70 here but I do know eps act up in really cold weather. If it only acts up in cold weather then I don't think there's a solution to fix that problem. if it acts fine in hot weather I wouldn't bother with it
Old Mar 9, 2012 | 07:39 AM
  #70
I guess the flaw in the s2k eps system is it can't function correctly in colder conditions many experience this problem and I haven't herd of a solution for it
