Power windows
Old Jul 6, 2006 | 04:12 PM
SCCS2K's Avatar
Default Power windows
(sorry if this is the wrong area - should I post in "electronics"?)
Hmmm...what do you call this thing...
Does anyone's (driver side) "window-all-the-way-down-automatically" button not work? I can push it down "two clicks" but it still just stops as soon as I lift my finger...
I can't see how it could be the motor, so I'm guessing it's the actual switch...but then wouldn't it just not work altogether?
Thanks in advance for such a trivial question...
Dave
Old Jul 6, 2006 | 04:16 PM
Slows2k's Avatar
It's a contaminted pulser in the motor, and the only permanent repair without wiring in aftermarket auto down module is to replace the window regulator assembly.
There is a TSB covering this issue for 00-02 cars. Getting it coverend under warranty would be up to AHM goodwilling the repair.
Old Jul 6, 2006 | 04:35 PM
xviper's Avatar
Or you could give this a try and keep your fingers crossed that it'll hold for a while:
https://www.s2ki.com/forums/showthread.php?s=&threadid=131795
If you can't get it warranteed and it won't reset, get an "Autoloc" device. This will fix the auto-down feature and give you auto-up as well for about 50 bucks.
Model WC1000 ................ www.autoloc.com
Old Jul 6, 2006 | 07:27 PM
jimmij's Avatar
they are only $39.95
Old Jul 6, 2006 | 08:06 PM
xviper's Avatar
Only if you get shipping free and you don't pay tax.
Old Jul 6, 2006 | 10:16 PM
chaboud's Avatar
What's the TSB? I ran in to a buggy auto-down on my 02 that magically went away recently.
It sucked.
Old Jul 7, 2006 | 07:45 AM
SCCS2K's Avatar
Wow, thanks guys! I'll try that trick you linked to first.
Side note - is there a complete list anywhere here on TSBs or recalls? Can't seem to find one, but I'm having a hard time searching successfully here.
Thanks again!
Old Jul 7, 2006 | 08:37 AM
xviper's Avatar
You shoulda looked in the "Library".
https://www.s2ki.com/forums/index.php?showforum=145
climhazzard
Sep 21, 2014 06:09 AM
S2K KiDD
Mar 16, 2006 02:49 PM
djohnston
Sep 27, 2003 12:06 PM
Molly W
Nov 26, 2002 10:06 AM
firsts2k
Aug 1, 2001 12:33 PM
