Problem with start
Old Aug 22, 2014 | 11:21 AM
CyS2k's Avatar
Default Problem with start
Hi everyone, last few days I have been having an issue when starting the car (2004 ap2); I have to crank the engine several times before it starts. The first coupe of times it feels as if there is no fuel then it gets fuel and starts a bit rough for a few seconds and after that it runs ok without any problems. From what I read in other threats it sounds that it could be the fuel regulator but when I pulled the vacuum hose out I didn't see any fuel. I replaced the relay but that didn't do anything. If I shut it down and start it right away or a few minutes after there is no problem. A few days before it did that my car run very low on fuel, don't know if that had anything to do with it. I also bought the fuel filter but my mechanic says that it is a big job to replace that and if I do that I might as well change the fuel pump and assembly. The dealer wants about $500 for the fuel pump + labor so I need to know if that's the problem before I spend the money for that.
Do you guys have any inputs as to what it might be wrong before I start spending money changing things?
Quikie
Mar 17, 2010 08:24 AM
gerryk
Jan 6, 2008 08:37 PM
fperra
Oct 31, 2007 05:46 AM
S2K000
Jul 27, 2007 03:45 PM
mavericckk..
Dec 3, 2005 06:22 AM
