Pulling the rest of the block
Old Aug 27, 2005 | 07:26 AM
FF2Skip's Avatar
Thumbs up Pulling the rest of the block
The head/intake have already been removed. Does anyone have any shortcuts or tips/tricks that might expedite my adventure today?
As always, thank you in advance.
Ex: SlowS2K told me to go ahead and remove the alternator to allow easier access to the intake manifold bracket bolts.
Old Aug 27, 2005 | 07:33 AM
Ztec's Avatar
Don't disconnect any AC lines, just unbolt it and move to the side - good luck Skip!
Old Aug 27, 2005 | 07:34 AM
FF2Skip's Avatar
Nick, next time, could you respond a little faster. I had planned on dropping it out under the car... I have no hoist.
Thanks! How's your beast running? Broken in yet?
Old Aug 27, 2005 | 07:43 AM
duff0000's Avatar
On a side note, Is it easier to pull the entire engine out , then take the head off, then remove the block?
Let us know how it goes Skip.
Old Aug 27, 2005 | 07:55 AM
FF2Skip's Avatar
I hope I never know first-hand!
I pulled the head to find a problem. I found more than I wanted and continue to have disturbing nightmares from it!
Old Aug 27, 2005 | 07:59 AM
Ztec's Avatar
Sorry, I will try and be faster I hope I caused you no trouble!
My motor was pulled from the top and can be re-installed with head and intake mani already installed if you do it from the top!
I left the tuner yesterday with a very conservative tune A/F 11.2 Very safe timing at 398 hp and 245 torque - He knows I track the car so he wanted to play it safe but there is room to squeeze more power but I don't know if I will go down that road! I have to work out some coolant temp problems, Other than that all is good (SO FAR )
D1sclaimer
Dec 3, 2023 10:13 AM
liybzd
Jan 31, 2014 02:19 PM
ChefJ
Aug 12, 2009 04:42 PM
ChefJ
May 18, 2009 05:11 AM
John_Z
May 12, 2006 08:04 AM
