Pulsating Idle with CEL p1519
Old Nov 21, 2010 | 09:21 PM
non_user's Avatar
Default Pulsating Idle with CEL p1519
So i turn on my car from a cold start last week and a check engine light immediately pops up and the idle starts going crazy/ pulsating. it sounds like im lightly revving the motor in half second intervals however my foot is not on the pedal. I check the code and it says p1519(idle air control valve circuit failure). The only way i can drive the car is to reset/clear the check engine light so it doesnt rev however upon letting the car cool, the cel comes back on and i'm at square one.
Just to inform you guys, i have no modifications done to the motor. it is a 2001 s2000 with 46,000+ miles.
What I've done: MAP whack with zip tie(as you can see in the video) and thoroughly cleaned the IAC valve.
I'm assuming i need a new IAC. What do you guys think?
1)Cold start(70 degrees outside) Havent driven the car in 2 days.[media]http://www.youtube.com/watch?v=uTPh63N8ouY [/media]&feature=mfu_in_order&list=UL
2)Let the car run for 5 min. then turned it off and turned it back on[media]http://www.youtube.com/watch?v=MNRZn3rfH_w [/media]&feature=mfu_in_order&list=UL
3)motor shot( may or may not be relevant)[media]http://www.youtube.com/watch?v=5W7ZrqQHmlw [/media]&feature=mfu_in_order&list=UL
Thanks for reading/watching. Diagnosis?
Old Nov 22, 2010 | 12:16 PM
00wreckedS's Avatar
bad tps?
Old Nov 22, 2010 | 12:22 PM
Calamari's Avatar
I seem to be having a simular problem as well, though I havent checked what CEL code I have yet.
Mine pulsates too, on cold starts, but doesnt fluctuate as much as yours does. however it is definatly notable by the exhaust tone and the digital needle going up and down.
Do you still get the lumpy idle after driving around for a while (fully warmed up)?
Old Nov 22, 2010 | 04:56 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
IAC, or connector.
If the idle is fluctuating up and down, and no code is present, the valve is sticking and needs to be cleaned.
Old Nov 22, 2010 | 07:35 PM
non_user's Avatar
the idle affects my balancing the clutch so i just leave the car. tried driving a half mile to a friends house and couldnt make it.
Old Nov 22, 2010 | 07:38 PM
non_user's Avatar
Originally Posted by Billman250,Nov 22 2010, 05:56 PM
IAC, or connector.
bought a new IAC so i will be installing it when it arrives tomorrow. hopefully its not a connection problem.
Thanks for the responses guys. anyone else?
Old Nov 23, 2010 | 07:38 AM
corpuszero's Avatar
i have the same problem, someone help!
Old Nov 23, 2010 | 01:57 PM
Calamari's Avatar
please let us know how the problem solves after you install the iac
Old Nov 28, 2010 | 06:24 AM
non_user's Avatar
UPDATE:
installed a new iac and all is fine. 150 miles and several start ups with no problems.
definitivo
Nov 27, 2012 09:58 PM
EnvyMyS2K
Sep 3, 2012 11:55 AM
hrpfg2
Mar 24, 2012 10:40 PM
Fujin
19
Mar 23, 2011 07:25 AM
Fatcow21
Sep 12, 2008 07:52 AM
