Question about ECU reset
Old Apr 2, 2017 | 08:26 PM
dv55xc's Avatar
Default Question about ECU reset
Recently I re flashed my ecu back to the stock map. I went to get my car smogged but the tech told me that the o2 sensor was not ready yet. I drove the car for 300 miles after and it still has shown the "ready" status on the tech's code reader. How long should it take for the ecu and o2 sensor to be "ready"?
Old Apr 4, 2017 | 01:39 PM
cdelena's Avatar
I don't know if it will fix this problem but I have found that a true reset of the ECU only happens with a power reset, which means pulling the battery cables.
Old Apr 4, 2017 | 04:23 PM
s2000ellier's Avatar
you need to do both highway (with cruise control) and city driving to get all the ready codes
Old Apr 5, 2017 | 04:16 PM
dv55xc's Avatar
interesting. I had no idea that you would need cruise control for this. I've been driving a lot of short distances in both city and highway. I'm going to step it up thus time and do a long drive with cruise control. I doubt need to drive at a certain speed do I?
Old Apr 5, 2017 | 04:17 PM
dv55xc's Avatar
if I do that I'll restart the entire process. That means driving even more than I have to.
Old Apr 5, 2017 | 05:42 PM
HarryD's Avatar
Originally Posted by Billman250
There is no mileage quota for any car ever made to make the ECU "ready" (meaning complete all monotors).
It goes by parameters, and them being met. Can happen in 3 miles, or over 200.
In some cars, conditions are picky and they will take over 150 miles to make ready. Basically, you are meeting the enable criteria on accident if you are not following the exact enable criteria, for that car, for EACH parameter (or monitor).
Lucky for us, the s2k monitors complete very fast, I have done it in 6 miles.
Fastest way:
Start the car cold in the morning, drive around local 5 minutes, shut it off (this will complete a "trip").
Start it back up, take it on the highway and set the cruise at 60 for 3 minutes (this will complete a second "trip", and make two-trip monitors "ready" like the air pump monitor).
Example: if you start the car cold, and drive it 10,000 miles without shutting it off, the two-trip monitors will never run and you will fail inspection It's all about parameters...not miles.
From: https://www.s2ki.com/forums/s2000-un.../#post21838123
Old Apr 7, 2017 | 11:05 AM
dv55xc's Avatar
Originally Posted by HarryD
Thanks for posting this! I couldn't find this using a search anywhere.
**Update**
I was looking at my basic scan tool that I got from AutoZone and decided to plug it in to the obd2 port. It showed the catalyst and o2 sensor under the category of "ready systems" or something like that. I'm gonna go back to the tester and have him check it out.
Old Apr 11, 2017 | 10:33 PM
dv55xc's Avatar
I passed smog today. I did everything that was in that link above. Now I gotta put everything back together.
UberDuper
Oct 17, 2015 03:41 PM
Chief Robert
May 26, 2012 05:26 AM
bjjs2k
May 24, 2010 03:03 PM
wotto1
Jul 6, 2007 05:32 AM
osc
May 31, 2005 06:50 AM
