Quick comptech supercharger question
Old Mar 20, 2003 | 08:31 AM
jlangton's Avatar
Default Quick comptech supercharger question
I am installing the supercharger right now and I have a VAFC for it.
Do I still need to put in the ESM module with it?
I seems as though the VAFC will do the same thing as the module.
Thanks,
James
Old Mar 20, 2003 | 10:24 AM
spapdx's Avatar
I know with vortech, you need all the electrical stuff that came with the kit. The vafc is an add on, not an either or. So I would say that you need to use both. I am not to familiar with the comptech kit but I am guessing that the box they gave you adjusts timming, and the vafc adjust air/fuel.
Old Mar 20, 2003 | 10:59 AM
RyanITV's Avatar
My understanding is that yes, you need to install the ESM. From what I remember, it only serves to prevent the ECU from seeing boost from the MAP sensor.
My VAFC is hooked up after the ESM (with the VAFC closer to the ECU than the ESM)... running it the opposite way could have unpredictable results.
Ryan
Old Mar 20, 2003 | 11:27 AM
Diddy's Avatar
[QUOTE]Originally posted by RyanITV
[B]My understanding is that yes, you need to install the ESM.
Old Mar 20, 2003 | 12:18 PM
1Randyc's Avatar
The unpredictable result would be like heavy bogging and hesitation when past part throttle.
Almost like hitting the rev-limiter and lots of bucking.
I had to live with that until my order of ESM came after my check valve version failed to work properly.
So as others have said, ESM is very essential part that cannot be left out.
The order is Mapsensor->ESM->Ecu->VAFC.
Old Mar 20, 2003 | 12:22 PM
sfphinkterMC's Avatar
YES
Old Mar 20, 2003 | 12:30 PM
RyanITV's Avatar
Err... ?
Wouldn't it be mapsensor->ESM->VAFC->ECU?
Old Mar 20, 2003 | 12:35 PM
turbo_pwr's Avatar
Err... ?
No. The VAFC can not work without a ECU (hence it's a piggyback system). I think you are thinking of actually physical connection.
Old Mar 20, 2003 | 12:40 PM
RyanITV's Avatar
[QUOTE]Originally posted by turbo_pwr
[B]
No.
Silver S2k4
Oct 3, 2007 04:07 PM
Silver S2k4
May 11, 2007 04:33 AM
pjonkheer
Apr 21, 2004 07:20 AM
Pakisho
Jan 19, 2004 02:52 PM
payyourtoll
Apr 30, 2003 02:10 PM
