random misfired between 3-5K
Old May 21, 2017 | 11:09 AM
rbund's Avatar
Default random misfired between 3-5K
I will start up the car in the morning, runs fine. Drive 35 miles to work. If I stop to tank up, and start the car after it's been stopped for 5 or 10 minutes, it seems fine, then when I take off, it starts to have slight random hesitations, like it's loading up,but a little rev (outside the 3-4K) makes it go away. I can put on cruise control, it will still misfire, but not as bad. When I get to work and parking at idle it will feel like a cylinder is missing. It also behaves like this in gridlock. It actually idles fine, but when accelerating, between 3 and 4,5K it will hesitate like a mild misfire. Coil Pack?
2005 S2K
181,000 miles
Old May 21, 2017 | 08:04 PM
yamaha6611's Avatar
2005 S2K
181,000 miles
when's the last time you changed your plugs?
Old May 21, 2017 | 08:05 PM
Gevik2133's Avatar
Check your sparks plugs. Most definitely 1 of your coils is bad you have to check to see what coil is bad.
roflitzjinno
Jul 10, 2008 07:49 PM
djblyss
Feb 6, 2008 04:56 AM
bumpins2k
Aug 18, 2005 03:36 PM
rai
Feb 8, 2005 04:16 AM
Hams2000
Aug 17, 2002 01:38 PM
