Rat Damaged my ABS
Old Jun 21, 2006 | 07:04 PM
ojaibob's Avatar
Smile Rat Damaged my ABS
I rat chewed through some wires on my ABS system and it no longer works. The rat chewed the wires just as they exit the plug that goes into the brake resevoir. Honda says I have to replace the entire wiring harnes. $260 for the harness and $1550 in labor. They say they will repair the wires for $15 in parts and $550 in labor but will not warrent a repair. They said my comprehensive should pay for it except I have a $1,000 deductable.
Has anyone run into this before and what have you done? I am not at all thrilled with a $1800 plus repair job. The good news is a killed the rat.
Old Jun 21, 2006 | 07:13 PM
krazik's Avatar
Administrator
1800+? you just said you had a $1k deductible. thats what it will cost you.
next time consider a cheaper dedutible.
Old Jun 21, 2006 | 09:11 PM
mikegarrison's Avatar
Yeah, I've got zero deductable on comprehensive. It's not that expensive.
Pay up or do the install job yourself. I wouldn't be keen on splicing together my ABS system unless I had a really good electronics guy do it for me.
Old Jun 22, 2006 | 05:11 AM
Wisconsin S2k's Avatar
i find it ironic that your entire post was perfectly laid out except for the fact that you switched an "i" and an "a" around in two completely different spots. it changes the meaning to make it sound like you chewed your own lines.
honestly, you should have extremely low deductibles for comprehensive. it'd probably cost you $5 more a month to drop to a $100 deductible on comprehensive.
hehe, i'm guessing no one has.
Old Jun 22, 2006 | 06:40 AM
Tyraid2K's Avatar
are you a teenage mutant ninja turtle?
Old Jun 22, 2006 | 06:54 PM
ojaibob's Avatar
Thanks for the input. What I was really looking for was not so much a correction of grammar or comments on my deductible, but comments on the mechanical advisability of a repair versus a replacement. For those who may be interested in that question, I have an answer from the Honda Service Manager. The ABS works off of micro volts. So, any repair is likely to alter the amount of voltage that gets to the system. Thus, a repair would probably have ongoing problems. Or at least there is a good chance it would. If the resistance is any greater or lower in the wires, then the ABS will not work. So, the answer is simple: replace the entire system. Anyway, this was my reason for posting the question and I had hoped that someone would have had experience with this or something like it.
Old Jun 22, 2006 | 08:42 PM
evf2000's Avatar
My ABS is broken there too...
ehhh I just left it off, I never really drive in bad weather. I might get it fixed someday but I've gone two years so....
liyan1430
Feb 23, 2019 01:25 PM
wylin
Nov 27, 2006 03:19 PM
BusterKnutt
Sep 15, 2005 09:57 AM
troutman
Dec 29, 2003 10:41 PM
madkimchi
Aug 20, 2002 08:43 AM
