REALLY NEED SOME HELP THROWING P0417 CODE
Old Apr 23, 2009 | 09:38 PM
swaps2000's Avatar
Default REALLY NEED SOME HELP THROWING P0417 CODE
CODE P0417 IS TELLING ME SECONDARY AIR INJECTION SYSTEM WHAT SHOULD I DO HOW DO I START FIXING THIS PROBLEM DID ANYONE ON HERE HAVE THIS PROBLEM
PLEASE HELP THANK YOU.
Old Apr 23, 2009 | 09:50 PM
03AP1's Avatar
1st: There is no need to shout. (Take it off CAPS LOCK)
2nd: The search function is your friend.
There are numerous threads about secondary air injection problems.
https://www.s2ki.com/forums/index.php?showt...&#entry11394653
3rd: If you plan on troubleshooting the car yourself, invest in a HELMS MANUAL. It is well worth the money you will spend.
Old Apr 24, 2009 | 04:10 AM
RIDGERCR's Avatar
I had this problem a couple years back and what I found it to be was the 2 air vacuum lines that plug into your secondary air box (thats what I called it anyway) are more than likely reversed and you might be hearing an audible "hissing" sound. This happened after I was finished modifying an AEM intake kit and it made perfect sense to me.
But do a search too as I found the culprit and fixed it right away.
Hope this helps ya.
Taku_Yoshida
May 25, 2010 02:42 AM
amusepanda
Apr 3, 2010 04:57 AM
theblackpearl
Jun 6, 2009 02:23 PM
CwickStylz
Aug 31, 2006 11:46 AM
EriS2k
Feb 11, 2005 10:17 PM
