Rear click/clunk
Old Feb 24, 2007 | 12:52 PM
KerryF's Avatar
Default Rear click/clunk
I'm getting a little slick/clunk when depressing the clutch at low speeds. Like when in reverse then depressing the clutch to put it in first, the tension on the drive train is released and I get a little clunk. This also happens when depressing the clutch in first a low speeds and when shifting to 2nd. The other day I heard a ping that sounded a lot like a bolt breaking. The sound started after that. So I'm assuming that something has come loose, maybe a diff bolt broke? I haven't been able to get the car up on a jack yet. Anyone have a good idea of where to look first?
Old Feb 24, 2007 | 06:56 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Rear axle nuts, guaranteed
It's the nuts right behind the rear wheel centercaps. Unstake it, remove it, grease the face of it, re-install it, torque it to 220 Ft-Lbs, re-stake it.
You can do the job through the centercap hole without pulling the wheels.
Old Feb 24, 2007 | 10:15 PM
KerryF's Avatar
Great, thanks. I'll check that out ASAP.
Old Feb 24, 2007 | 11:44 PM
nsxs2k's Avatar
Wow!! great info, thanks man
nateman101
Jun 19, 2011 12:31 PM
billiardboy904
May 17, 2008 07:14 AM
villeneuve
Aug 12, 2005 06:58 PM
KgBsUcKa
May 29, 2004 04:32 PM
Squeezer
Nov 26, 2002 02:18 PM
