Rear diff is dead, rebuild OEM or aftermarket?
Old Apr 11, 2017 | 10:17 AM
  #21
Rickford's Avatar
Default Would like your info...
Originally Posted by S2KPUDDYDAD
Hi, I have been a part of the S2KI club for about 13 years now and build and rebuild our differential I would be happy to send you some information on what I do, you can also do a search on the site
I do ship complete plug and play rears and I also repair sent in broken rears. I make improvement so the factory rear can handel more power and more spirited use.
Mr s2kpuddydad i would very much like your info on a stock rebuild formy 07 S2k. I'm logged in but don't know how to PM you? Have been reading tons of posts on the subject. Can you clue me in on tHe PM. Don't know what I'm doing wrong. Thanks very much! Quick question...Will flat towing screw anything up in the diff? Thanks again!
Old Mar 30, 2023 | 09:00 PM
  #22
HondaS4k's Avatar
Default S2000 Diff.
Hi sorry about the bad luck....please send me a PM I can help you with the diff. I rebuild and also upgrade the factory rear and have been doing this for the S2000 Community for many years
I need help with my diff, got some play.
Old Apr 2, 2023 | 07:15 PM
  #23
BrokeBoiS2K's Avatar
do you have a buisness phone number or social media?
Old Aug 30, 2023 | 06:18 AM
  #24
shuneycutt's Avatar
@S2KPUDDYDAD it looks like your message inbox has reached capacity and won't accept anymore PMs. Please shoot me a PM and let me know what the cost and procedure is to have an AP1 rear diff rebuilt.
Thanks!
-S
Old Aug 30, 2023 | 07:34 AM
  #25
spider2k's Avatar
Active Streak: 30 Days
Thanks!
-S
here is what he offers and the email
puddymodracing@gmail.com
This info shows you the work I do on S2000 rears. I also build R200 Nissan, BMW, Toyota, Ford, and Mazda IRS setups.
Gear ratios available for the S2000 are...3.33, 3.63, 3.73, 3.90, (stock 4.10) 4.30, 4.44, 4.56, 4.57, 4.77, and 4.88
This is some info on the rear builds I do, Stock build,
A Stage 1.5, 1.5+, 2, 3, and Stage 4
Stock build,
A clean reconditioned rear using stock OEM parts $1,075
Stage 1.5+
This is a rear that will be clean and reconditioned, have upgraded 10.9 bearing cap hardware and, cryo treated gears. The rear will also have a Heavy Duty (not stock but looks stock) crush sleeve.
The crush sleeve used in this rear is over 50 thousands heaver than a stock crush sleeve and will hold up much better than the stock unit. $1,200
PM Stage 2,
The rear is set up for N/A and boosted cars.
It is rebuilt from the housing in starting with every rotating part being cryogenically thermo cycled, then new pinion bearings and seals are used to assemble. There is a one piece PuddyMod solid steel sleeve used instead of an OEM crush collar. The solid sleeve is made of 10/20 mandrel steel, it is seamless and will not compress under heavy stress like the OEM can. Solid sleeves are used in high performance racing rear ends because they work. The PM sleeve is a custom made part to fit this rear, it is a one piece steel sleeve. The stock hardware is replaced with new 10.9 hardware. Backlash is set at 2 to 3.5 thousands giving a tighter gear to gear fit.
Full Blueprint assembly of rear using precision accuracy to better than factory tolerances.
$1,675
PuddyMod Special black Stage 3
130,000 PSI reinforcing strap.
New bearings, seals, and hardware are used
Black phosphate finishing (same process used in firearms )
Solid custom sleeved pinion (no crush collar) we use 10/20 mandrel steel (seamless) ARP hardware Backlash is set at 2 to 3.5 thousands giving a tighter gear to gear fit.
Price for the standard PM Stage 3 rear using a stock 4.10 gear ratio is $2,760
PuddyMod Stage 4
We fully cryogenically treat the rear, that is every part is cryo treated that can be. Fully built and reinforced housing that can hold upwards of 200,000 PSI stock is only 60,000 PSI New bearings, seals, and hardware are used Fully de-burred and polished gears for smoother cooler operation, less friction. Black phosphate finishing (same process used in firearms)
Solid custom sleeved pinion (no crush collar) we use 10/20 mandrel steel (seamless) Fresh PuddyMod signature paint on the housing Full Blueprint assembly of rear using precision accuracy to better than factory tolerances. 12.9 hardware used through out Modified Stock rear cover Price for the PM Stage 4 rear using a stock 4.10 gear ratio is $3,260
Delta_lima
Nov 26, 2017 05:51 AM
Edbun
Apr 3, 2015 11:23 AM
mtunreal
Nov 12, 2014 02:42 AM
Blue Gumby
Jan 15, 2011 11:36 AM
vishnus11
Mar 3, 2006 06:18 AM
