Rear end squeak's under braking
Old Jun 14, 2009 | 05:06 PM
ukrainefreighttrain's Avatar
Default Rear end squeak's under braking
The rear of the car squeaks under braking. When I'm really light on the brake or slam it all the way down there is no noise. However in between the two there is a high pitched squeak. I thought it was the pads so I changed those out (they didn't look worn though, probably had 35% left). Lubed the hell out of the caliper and pads. But it still makes the noise. The rotors still have plenty of life on them and the car doesn't vibrate under braking.
The car is a 2003 with 66k miles on it. Any idea what it could be? thanks guys.
Old Jun 14, 2009 | 05:23 PM
negcamber's Avatar
Did you put the anti-squeal shims on the back of the pads?
Old Jun 14, 2009 | 05:30 PM
I didn't put shims on it. The old pads had shims and before I put on new ones I lubed the hell out of the old ones with their shims and all but the noise has been consistent.
Old Jun 15, 2009 | 09:22 AM
bump
Old Jun 15, 2009 | 04:33 PM
negcamber's Avatar
If you didn't use the anti-squeal shims from the oem pads, then it's a good bet that is the problem no matter how much grease you used.
Old Jun 15, 2009 | 05:20 PM
that would make sense however the old pads had life on them, were installed with shims, and were lubricated. but still made the noise. Also the noise is exactly the same now as it was with the old pads which makes me think pads aren't the issue.
Old Jun 17, 2009 | 04:57 PM
also I just noticed there is a lot more brake dust on the drivers side wheel than the passenger side.
FISH22
Dec 9, 2010 02:09 PM
Deano_d
Apr 13, 2010 07:12 AM
UKjasonm
Aug 24, 2009 09:37 AM
tmkpres
May 21, 2007 10:16 PM
glove311
Jul 18, 2006 01:19 PM
