Rear Hub?
Old May 19, 2009 | 10:35 AM
dimi's Avatar
Default Rear Hub?
About 2 weeks ago I started getting this mad grinding noise coming from the back. First I thought the pads were done but that wasn't it. Then I thought the rotor was warped as it seemed to squeak in intervals as the wheel was spinning. Rotors seemed to be fine upon inspection.
I had a buddy do an alignment for me a few days ago and no surprise the wheel making the noise was way off. The problem happens while on the brakes or when the clutch is disengaged and cruising. When i engage the clutch it goes away. Is this the rear hub and how would I diagnose its failure.
As well I broke one of my front wheel studs. How would I go about replacing one, hopefully without replacing the hub.
Thanks
Old May 19, 2009 | 02:58 PM
negcamber's Avatar
First on the wheel stud...take a look in the DIY FAQ...there are couple sets of DIY instructions in there.
For the noise...try greasing the caliper pins with a good high temp lithium grease. Sticking calipers can sometimes make that sound.
Old May 19, 2009 | 03:23 PM
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
My rear driver side wheel made a high pitch kind of metallic noise as well. It turned out I needed to repack my wheel bearing. So I took off my wheel and used my air gun to unbolt the axle nut. Then I gunned it back on really tight. I repeated this about 4 to 5 times. Then the noise was gone.
J.nguyen
Dec 4, 2008 04:40 PM
boosted_ap1
Apr 18, 2008 05:58 AM
suzukawoods
Jan 11, 2006 09:18 AM
JimmyB
Aug 29, 2005 02:21 PM
