Red line and rev limiter specs...
Old Nov 2, 2001 | 05:30 PM
Luis's Avatar
Default Red line and rev limiter specs...
I have asked this question before with no definite response.
Now that I have the spa shift light and rev display I can confirm that the redline, that is the rpm point where the rev counters flashes, it's 8900 rpm and that the rev limiter kicks in at 9200 rpm.
The gauge is accurate to 0.05% so the numbers are pretty accurate.
Old Nov 2, 2001 | 05:35 PM
Mike Schuster's Avatar
Who sells this gauge and where did you mount it?
Old Nov 2, 2001 | 08:36 PM
pfb's Avatar
pfb
Originally posted by Luis
Now that I have the spa shift light and rev display ...
Cool. Let's see the installation pictures!
Available in the US here...
http://www.racingforce.com/products/spa/shiftlight.htm
Old Nov 3, 2001 | 03:39 PM
Luis's Avatar
We took it apart, unsoldered the LCD, connected it thru a flat cable, installed the control unit out of sight, the gauge button on the switch blank to the right of the steering wheel and powered it thru a master switch that I can use to turn it off if I want it. I'm still missing the backlighting on the LCD that will go in this week.
Here are the pictures (previously posted at https://www.s2ki.com/forums/showthread.php?...?threadid=29422).
mikecl713
Aug 12, 2003 06:13 AM
peltier
Dec 6, 2002 04:50 PM
LarryD
Nov 27, 2002 12:25 AM
optical
28
Oct 4, 2002 06:28 AM
xfactor834
Aug 16, 2001 07:00 PM
