Remote open/alarm not working
Old Dec 17, 2004 | 08:26 AM
DaveOnLI's Avatar
Originally Posted by RACER,Dec 17 2004, 02:13 AM
Do all S2K's come with alarms?
No. It's an option.
Old Dec 17, 2004 | 08:52 AM
centralcoastbuc's Avatar
The Honda OEM alarm system also has 2 inline fuses in the alarm harness near the fuse box. If it was installed properly per the manufacturers instructions there should be stickers on the inline fuse housings labeling them as such. They are little rectangular boxes built into the harness very close to the actual fuse box, but you may need to remove the plastic kick panel to locate them.
This information is based on the system I just installed in my '04. I am not 100% sure that they have always been that way on all earlier models, but I see no reason why they wouldn't be.
Steve
Old Dec 17, 2004 | 12:23 PM
Lovetodrive2000's Avatar
Dang... guess I'll go pull the fuse and put it back in....
I'll do it tomorrow... hope it works....
Old Dec 18, 2004 | 05:36 AM
That is unreal.....
Just went out and pulled the fuse, wiped off the contacts, checked it, put it back in and.....
It works!!!!!
Thanks for the help!!!!
I owe you a beer stefluva !!!!
Old Dec 22, 2004 | 08:32 AM
LostWaffle's Avatar
I pulled the fuse last night, and it also worked.
BUT, THIS MORNING IT WASN'T WORKING AGAIN!!!! I spent 5 minutes waking up all my neighbors because I couldn't turn off the alarm. Finally, in a last ditch effort I pulled the remote fuse again, and the alarm turned off. (which gives me security concerns actually) Is it that easy to defeat the alarm?)
Does anyone have a theory on why the remote could be reset so it worked but then would stop working again?
Much appreciated.
Old Dec 22, 2004 | 12:56 PM
Much appreciated.
When I read your post, I went back out to try mine again....
And it didn't work!!!!
But then I got the other remote and it worked!!
This is going to drive me crazy!!!
Old Dec 22, 2004 | 12:57 PM
I know with my Acura, I can reset the alarm (if I can't get it to turn off), by putting the key in the door lock and locking it, then unlocking it.....
Old Dec 22, 2004 | 01:53 PM
LostWaffle's Avatar
ooohhh. That's an awesome tip about resetting the alarm. I'll try that.
Did you make sure to configure both your remotes at the same time? Maybe that's why one works and one does not.
Old Dec 22, 2004 | 02:06 PM
I never could re-program my remotes....
Once I pulled the fuse and put it back in... both worked.....
I'll wait a few days and try again.....
Old Dec 25, 2004 | 05:24 AM
Tried it yesterday, neither remote worked on the first, second etc try....
Took myabe 10 tries and it finally unlocked the doors....
Guess pulling the fuse wasn't the magical solution....
Any other ideas?
