Removing Crank Pulley Without Special Tool
ok, ive searched everywhere and i can find the crank pulley tool, even honda doesnt have it they are ordering a new one. but is there any way to remove the crank pulley without this tool??? any ideas would help...
Your Snap-on or Matco tool rep should have one. Here is a link to buy it online from Matco HARMONIC PULLER HOLDING TOOL
are you talking about removing the bolt itself? or a puller? If you have gotten the 19mm bolt out already but cant slide the pully off... you can try using a prybar and give the pully taps with a brass hammer, thats what i do at lexus and works just about everytime. if that doesnt work then you are going to need a puller.
If you are talking about the bolt itself that you cant crack loose... see if anyone has a powerful 3/4" impact gun if you can fit it in there. maybe use a little heat but not too much.
