Removing drive shafts
Old May 18, 2011 | 07:50 PM
p0staboy's Avatar
Default Removing drive shafts
I'm trying to remove my right side drive shaft and I'm not sure which part of the hub I have to take off to get the axel out.The diy on here says to take the lower a arm ball joint off but the shock is connected to that a arm also so would I take off the bolt holding the shock? Do I have to take off the tie rod ball joint to swing the hub to get the axel out?
Old May 19, 2011 | 09:53 AM
starchland's Avatar
The shock is attached to the lower a arm,which is separated from the hub when you separate the balljoint, the whole hub assembly should swing out of the way leaving access to the axle
Old May 19, 2011 | 10:16 AM
k1ng124's Avatar
Old May 19, 2011 | 12:45 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Dont touch the shock.
-remove 10mm bolt holding abs sensor in and remove abs sensor from knuckle. If you dont, you will break the wires internally when you pull out on the spindle.
-remove 36mm nut on axle
-remove 17mm nut on bottom ball joint
-using ball joint breaker, pop lower ball joint
-remove 6 bolts hold axle to dif
-swing knuckle outwards, remove axle spline from hub, then slide axle out of dif and out of the car
Old Oct 11, 2012 | 12:06 PM
refect's Avatar
Bringing this post back from the dead.....would you need an alignment after changing your axle this way? It seems you would because you are messing with your suspension when disconnecting the ball joint. However, you havent really messed with the bolts that actually adjusts camber and toe....?
kgregg
May 12, 2018 08:35 PM
Slammed_s2k
Jul 9, 2015 07:47 PM
duff0000
May 5, 2007 04:02 PM
donger274
Feb 13, 2007 01:30 PM
