removing the sensor from the cat
Old Feb 28, 2008 | 05:54 PM
breakneckS2k's Avatar
Default removing the sensor from the cat
sorry if this is already somewhere, I'm kind of in a pinch.
I'm in the middle of installing my J's 70RR (thanks Ken!), and I can't get the sensor out of the cat...
does it screw out?
does it pull out?
any and all suggestions would be appreciated...
Old Feb 28, 2008 | 05:59 PM
hondafied's Avatar
it screws out its a 22mm
Old Feb 28, 2008 | 06:02 PM
nevermind got it. mods close
Old Feb 28, 2008 | 06:04 PM
2poor2mod's Avatar
you have admin function on your own threads and can lock them yourself. Lower right hand corner under moderation options.
Old Feb 28, 2008 | 06:19 PM
no. mods don't close! don't close!
I have another issue.
Will I regret it if I remove that little cross-member that's right in front of the differential?
but thanks hondafied for the info!
Old Feb 28, 2008 | 06:30 PM
2poor2mod's Avatar
just remember to put it back you wont hurt anything to take it off to install your exhaust. good luck
Old Feb 28, 2008 | 06:31 PM
well damn.
broke one of the bolts on it...
let's see if I can get the others off w/o breaking them...
thanks man!
Old Feb 28, 2008 | 06:40 PM
hypothetically, if I get the crossmember off and don't put it back, will it be totally devastating?
b/c I can't get the oem exhaust out without taking it off, but I don't think I can get it off w/o breaking the bolts...
Old Feb 28, 2008 | 06:57 PM
2poor2mod's Avatar
that piece imho needs to go back on. it is the rear lower tie bar. if you break the bolts drill them out and get new ones
Old Feb 29, 2008 | 04:54 AM
AssassinJN's Avatar
I swapped my exhaust a bunch of times lately and finally snapped 1 of the bolts there (had some salt corrosion), a quick run with one of the good bolts to a mechanic or home improvement store will get you replacements.
InVTEC
Jun 16, 2016 01:26 PM
2000BBS2k
27
Feb 24, 2014 09:53 AM
mobile chicane
Jan 18, 2012 05:22 AM
davidc1
Dec 19, 2010 08:44 AM
S2KballinOut
24
Apr 21, 2010 08:57 AM
