Replacing cyclinder head
Old Dec 1, 2010 | 10:48 AM
aqahmed's Avatar
Default Replacing cyclinder head
Hello Guys, I got a 2000 s2000 and am having cylinder head issues for a while now. About 2 years ago I had some valves burnt so had a local mechanic fix it. The problem is that all the problem (CEL, cyclinder misfire, etc) came back. I had the valves adjusted and a leak test done...cyclinder 3 only had about 140 lbs!!! I am gonna check the retainers to make sure that they are fine.
I also got a brand new complete head that I am gonna put on now to fix the problem, I think my old head is done... The question I have is that the manual says that I need to adjust the idle rpm after replacing the head???? Is this really required? Can I drive without adjusting that? Worst case it will be off by couple hundered rpms....
Thanks
chris2k03
Jul 23, 2009 09:08 AM
Jacques79
Aug 20, 2007 12:31 AM
SpiralF20
Mar 6, 2006 02:26 AM
