Replacing driver rear spindle....
Old Sep 24, 2010 | 04:26 PM
CHEESEFRIES333's Avatar
Default Replacing driver rear spindle....
after this thread... https://www.s2ki.com/forums/index.ph...pic=818307&hl= ..... now i need to know how to install a rear spindle. Any help would be greatly appreciated
Old Sep 24, 2010 | 06:04 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you got a complete hub assy, you will save some work because you dont need to press anything.
Remove wheel
remove 10mm bolt for wheel speed sensor and remove speed sensor.
remove caliper, and rotor. You will likely need a handheld impact driver to loosen the phillips screws holding the rotor on.
You have 3 tapered links (all have cotter pins) you need to break loose. upper ball joint, lower ball joint, and trailing arm. Since you are not changing any links, you cannot use a fork because it will destroy the boots.
you will need a ball joint tool.
you will need a 36mm socket for the axle nut. The axle nut must be tightened to 220 or you will waste another bearing.
ball joint tool on the left. It works for the lower, but may not fit for the other 2. you may need a different style.
Old Sep 24, 2010 | 06:08 PM
TopGear's Avatar
Here's a DIY. I've never heard the rear knuckle referred to as a rear spindle, but I'm pretty sure it's what you're talking about. If this thread doesn't make sense, you should consider getting help, or taking your car to a shop. This isn't the sort of thing you want to get stuck half way through.
https://www.s2ki.com/forums/index.php?showtopic=223599
Found it in the sticked "FAQ's DIY's and Maintenance Thread" - https://www.s2ki.com/forums/index.php?showtopic=548714
Always the first place to look when you have a question.
Make sure you have the same style ball joint separator that is shown in that DIY. I was strongly warned against using a "pickle-fork" type separator when I was doing mine.
Also, an impact wrench is VERY convenient for getting the axle nut off.
Other than that, it's not too complicated. You might need to have a medium sized c-clamp on hand in case the ball joints start to spin when you put them back together (as happened to me). There's an example of that in this DIY: http://robrobinette.com/S2000Bearing.htm
Anyway, good luck
edit: I second billman's suggestion of the impact screwdriver. That thing was so convenient that I actually forgot that I used it!
WarrenW
Jun 10, 2018 01:34 AM
Slammed_s2k
Jul 9, 2015 07:47 PM
p0staboy
Oct 11, 2012 12:06 PM
p0staboy
May 10, 2011 06:19 PM
