required upgrades before SC?
Old Jan 16, 2004 | 06:59 AM
S2000_Europe's Avatar
[QUOTE]Originally posted by wortham
i just got this posted last night.
Old Jan 16, 2004 | 09:11 AM
F1s2000's Avatar
You can keep the stock exhaust and remove the cat with a straight pipe. The flow will be less restricted.
Old Jan 16, 2004 | 02:52 PM
jerrypeterson's Avatar
And reducing this supposed exhaust flow restriction will get you what? Are you sure there is a restriction in the first place?
Old Jan 17, 2004 | 07:38 AM
3ngin33r1's Avatar
Every man wants a smoother flowing pipe.
Old Jan 17, 2004 | 09:22 AM
vindiesel's Avatar
Originally posted by tritium_pie
since the clutch is a wear item (and an expensive one, at that), you might as well keep using the OEM clutch until it starts to slip, and only then replace it with an ACT.
therefore, IMHO upgrading the clutch before installing the SC (as per your title) seems to me to be a waste of $.
$.02
I replaced the clutch at the same time as the S/C install.I figure the car was more fun when I did it together.I wish I had the 4:77 gears installed at the same time.If your going Vortech your oil pan comes off anyway.It'll be a big change for you.Have fun.Do it yur own way...
Old Jan 17, 2004 | 10:38 AM
Old Jan 18, 2004 | 02:55 PM
Harry are you older/most experience owner with SC?
how is your engine? do you have any sign of stress? do you track the car.
Old Jan 19, 2004 | 01:07 AM
thanks harry!!!
Matt_ks_001
Oct 6, 2008 05:04 PM
Radfords2k
May 19, 2007 09:20 PM
Reaper 6A
May 5, 2007 03:06 PM
Akilldema
Mar 27, 2006 07:28 PM
S2KBilly
Apr 25, 2005 08:40 AM
