Reverse gear
Old Jul 1, 2005 | 10:19 PM
cyman83's Avatar
Default Reverse gear
sorry this may seem weird, but i went to test drive a s2000 the other day. and unlike the ones i've driven before, the reverse gear on this on wasnt required to be pushed in to engage..was wondering if something could be wrong, and i should avoid
Old Jul 1, 2005 | 10:56 PM
k3werra's Avatar
Banned
edited by xviper - post is completely senseless, useless and serves no purpose.
your following posts explaining your drunkeness will be deleted.
Old Jul 1, 2005 | 10:58 PM
cyman83's Avatar
Originally Posted by k3werra,Jul 2 2005, 12:56 AM
edited by XV
um im not quite sure what u're saying. like when i try to shift to 6th, usually theres a lock out for the reverse gear on the far right side. but on this one, i can slide into the far right without pushing down
Old Jul 2, 2005 | 06:38 AM
cyman83's Avatar
someone help!
Old Jul 2, 2005 | 06:48 AM
xviper's Avatar
It would seem that the spring that holds the stick up is not doing its job. It's either broken, missing or the stick itself is so stiff (up and down wise) that the spring isn't strong enough to keep it in the up position. Can you actually pull the stick up to its normal resting position?
Old Jul 2, 2005 | 12:45 PM
cyman83's Avatar
[QUOTE=xviper,Jul 2 2005, 08:48 AM]It would seem that the spring that holds the stick up is not doing its job.
Old Jul 2, 2005 | 01:39 PM
xviper's Avatar
Originally Posted by cyman83,Jul 2 2005, 01:45 PM
would this be a problem with the spring? is it fixable?
Yes, it's fixable.
dievoche
Dec 16, 2010 11:56 AM
INDYMAC
May 3, 2006 06:40 PM
tomcapek
Jan 12, 2006 10:04 AM
Squeezer
Apr 26, 2004 10:19 AM
Y2TuCkY
Mar 22, 2004 03:03 PM
