Ring and Pinion backlash theory
Old Feb 12, 2004 | 01:18 PM
moparacker's Avatar
Big Ben is on the right track, decreasing the backlash could increase gear whine along with increasing rearend temps.
Old Feb 12, 2004 | 01:48 PM
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by moparacker
That backlash is pretty tight as it is. I know on Ford rearends, a .008-.012" backlash is ideal per the manual.
Old Feb 12, 2004 | 02:33 PM
moparacker's Avatar
*edit for being irrelavant info due to my blindness.
Old Feb 12, 2004 | 02:44 PM
Gernby's Avatar
Former Sponsor
7.5", 8.8", 9.75" and 10.25"
I rechecked the specs to what I put:
0.008-0.015" maximum
Old Feb 12, 2004 | 02:47 PM
moparacker's Avatar
Ok, I'm sorry. I misread your numbers gernby. I was reading them as being smaller for whatever reason. You might be right on dropping the backlash a bit, but the two previous concerns would still apply. These rearends whine quite a bit stock, so dropping it could really make it loud.
Old Feb 12, 2004 | 02:54 PM
Slows2k's Avatar
I'n my experience, the closer to the minimum backlash # the quieter the gear set will be, as long as the contact pattern is correct. The higher the backlash # the noisier the gear set will be. The backlash only increases as the gear wears. Excessive backlash the noisier the gear and the gears are "shocked" every time power is applied.
Improper pinion depth, incorrect engagement pattern, are the larger issues that cause gear noise and ultimately failure.
Old Feb 12, 2004 | 02:56 PM
Slows2k's Avatar
BTW, I set the backlash on my gears at .002 And haven't had any noise from them
Old Feb 12, 2004 | 03:26 PM
Gernby's Avatar
Former Sponsor
I measured the outer diameter of the ring gear, and it looks like it is about 7" at the far extent of the teeth.
Old Feb 12, 2004 | 03:42 PM
Big Ben's Avatar
THe outer measurement is the size of the gear. Mazda makes a 6", 7", and an 8". But the 4.44 is a 7.5". And there are less 4.44's than any other gear.
This is what I gather from what I have read of course.
wicked357
Jul 30, 2012 01:44 PM
Infidel99
Dec 20, 2008 06:50 AM
hondaboy82
32
Feb 12, 2006 05:27 PM
jwa4378
May 24, 2005 03:30 PM
s2kdarren
Aug 9, 2004 07:44 AM
