rough idle only when a/c is on
Old Jul 8, 2012 | 02:35 PM
charlesardolino8's Avatar
Default rough idle only when a/c is on
Ive noticed that when my ac is on in my ap1 the idle drops really low and is rough was wondering if anyone else had the same issue and what they did to fix it or do i just have to live with it? I also noticed when there is a load on the engine. Headlights, putting top down etc....the car only has CAI with 96k!
Old Jul 8, 2012 | 07:13 PM
alphalanos's Avatar
my car drives noticeably crappy when the AC is on. slower, not as smooth, idles weird. possibly compressor issue I think
Old Jul 8, 2012 | 07:44 PM
sillyboybmxer's Avatar
the ac is crappy in this car. and it robs lots of power(says in the manual)
Old Jul 8, 2012 | 07:49 PM
T-Smac's Avatar
Clean the throttle body. Clean the IAC Valve. Check the serpentine belt tension and the belt for wear.
Old Jul 9, 2012 | 07:26 AM
Yeah ive already done all that but its still the same!
Old Jul 9, 2012 | 10:27 AM
Supra-holic's Avatar
You done a valve adjustment yet on the car? How bout plugs?
Old Jul 9, 2012 | 06:20 PM
Yes both have been done everything maintenance has been done
Old Jul 9, 2012 | 08:43 PM
rob-2's Avatar
You might try relearning the idle again. MIGHT be a free attempt to resolve the problem.
Old Aug 2, 2012 | 07:03 PM
mbs's Avatar
mbs
+1. Same problem here. Return-to-idle is bad on my '00 only with A/C running. Car bogs below idle and then returns to normal. Happens when stepping on clutch, revving engine, etc, with a/c running. With A/C off the car does not bog whatsoever.
I have:
1. Performed idle re-learn procedure, no change
2. Replaced most vac lines, found some were a bit worn
3. Replaced air filter, old one was pretty gungy
4. Replaced PCV valve and tube, old one was still rattly but maybe overly rattly
5. Cleaned IAC valve with carb cleaner, unsatisfying as the moving parts cannot really be accessed or exercised
6. Replaced IAC valve and lines
7. Performed A/C signal circuit troubleshooting, looks good
Next steps: IAT (air temp) sensor?
Any ideas/hints?
Update: Performed A/C signal circuit troubleshooting procedure which resulted in all normal. Upshot is if your A/C works at all, that circuit is good And you can tell real fast by pulling the a/c pressure sensor electrical connector, cause the A/C doesn't work with it pulled.
@Supra-holic -- to be clear about the clutch thing, I believe it's only because the revs fall to idle when stepping on the clutch that the problem tends to occur then.
I read some folks bitching about similar problem with Civics -- in some places the consensus is that this can be due to a dying A/C compressor.
Old Aug 3, 2012 | 10:52 AM
Clean your throttle plate and check your valve clearances, adjust if needed. Map wack? If those don't help, try compression test.
That is weird that it bogs when on the clutch, that is a symptom of crank walk?
Shabadedoo
Sep 8, 2010 05:36 AM
cvedral
Jan 29, 2010 03:09 PM
gdmedic
Nov 27, 2009 04:04 PM
S~Factor
19
Apr 17, 2008 08:28 AM
