rough idle, power is down, misfiring?
I've seen a few other threads and attempted to diagnose the fault but to no avail, so until i can get my car to my mechanic next week, perhaps you guys could help!
Symptoms
- idles rough. Upon start up it'll idle normally but as soon as i touch the throttle or turn on the AC, the idle will sounds like a WRX
- its down on power, i'd estimate its down roughly 25%. maybe more.
- i've removed all 4 plugs, all covered in dry black soot. The plug closest to the radiator was the blackest. whereas the last 3 plugs were black, but the tips were greyish.
pic of plug no 1 https://imgur.com/a/9wVMc
- theres definitely an odd smell. running rich i guess.
- no CEL warning
so far i've tried:
cleaning the ICAV unit, no change
cleaning the MAP sensor, no change
replacing the spark plugs, no change
i've lifted the coilpacks individually. each time the car's idle would dip so i'm guessing they're all working ok?
i've put my ear against a screw driver which was placed against each injector. all 4 seem to click consistently.
the first (upstream?) o2 sensor is covered in dry black soot.
the rear o2 sensor is light greyish.
Australian spec so no OBD2 port.
new tank of fuel
have not done a valve adjustment, but i'm assuming the problem would not come on so sudden?
have not done a leakdown test or compression test yet.
the other thing is the car was not driven for 5 months but i've driven it for 2 weeks since then. All was well, plenty of power, until one morning it just started to play up.
Any ideas?
Symptoms
- no CEL warning
so far i've tried:
new tank of fuel
Any ideas?
You aren't getting any CEL errors? Or if no OBD-II = no CEL light?
What is the oil consumption? Looks like an O2 sensor issue. ( WAG).
BTW... what spark plug heat range did you put into the car? Maybe, too cold?
Thanks.
Thanks.
My 1999 model doesnt have the OBD2 port from what i've read.
yeah i'll do one soon.
although the issue came on very suddenly so i'm guessing its probably electrical?
similar specs to the platinum ones i took out but made no improvement.
The comp and leak down test is definitely worth doing, certainly with the mileage on your motor, but if you have a friend in the club that is so willing, id be curious to see if your problem goes away by simply swapping in good known coil packs. Its possible they could be tired, enough to combust under low fuel demands such as idle, but under load spark is weak and wants to poop out. Its a theory based on your list and symptom, so definitely worth trying if you can get your hands on a set.
So moral of the story is, test your coils by disconnecting the plug, instead of lifting the coil off the spark plug
If you only replaced one ignition coil, be prepared for the rest to go out.
