royal purple differentail fluid
Old Jan 22, 2009 | 04:33 PM
silvery2ks2k's Avatar
Thumbs up royal purple differentail fluid
anyone know if this is any good for the s2k its cold out so i figured it would be ok to use
Old Jan 22, 2009 | 04:40 PM
DFWs2k's Avatar
I used this when I changed mine last weekend....obviously don't have long term results yet
Old Jan 22, 2009 | 05:04 PM
ok i figured with it costing more there was more put into making it and thus being a better product than the mobil one.
Old Jan 22, 2009 | 05:15 PM
aLcm's Avatar
im using it i have 7k miles on it now with no problems.
Old Jan 22, 2009 | 05:22 PM
RickIsYoDaddy's Avatar
i have it in my diff too.. im about 6k miles too. Its about 10 degrees here in korea and no problems yet. (knock on wood)
Old Jan 22, 2009 | 05:47 PM
ok sounds like it should be ok now im just waitin on some new washers to come in tommorow from honda and ile get it changed.
Old Jan 23, 2009 | 03:03 AM
INDYMAC's Avatar
If you want to get some idea about how RP 75W-90 GL5 stacks up to other commonly sold gear oils for diffentials in general go here:
http://www.amsoil.com/products/gearl...hitePaper.aspx
If you are looking for UOA's on RP gear oil to compare it to other brands, I am not aware of any for the S2000. But I do know that Mobil1 75W-90 GL5 compares very well with LE607 (discontinued now) in the S2000, even though it is not as viscous. I have only seen one UOA of Redline 75W-90 GL5 in the S2000, and the wear metals were unacceptable to me.
I'm currently trying LE1605 and haven't done a UOA yet (5K miles so far). If a cold climate were my concern, I would try AMSOIL SVT 75W-110 first. If that wasn't available, I would try M1 75W-90 or 75W-140.
Old Jan 23, 2009 | 08:37 AM
MasterForce's Avatar
At first i went with RP Max Gear 75-90W from Auto Zone. Did some searching and i found more great reviews for M1 than RP..i decided to exchange the RP for M1..this was this past wednesday....so far its good, but im sure RP is prolly the same...
If you do go with whichever just remember you can always change it...
Old Jan 23, 2009 | 09:51 AM
mikdys's Avatar
I don't know about their transmission oils but Royal Purple engine oil gets a pretty good write up here :
http://www.animegame.com/cars/Oil%20Tests.pdf
t8krisk
Apr 22, 2014 11:39 AM
hypforlife32
May 12, 2010 04:38 AM
S2k007
Feb 24, 2010 05:00 AM
Empedocles99
Feb 17, 2007 07:04 PM
UCrazyKid
Sep 1, 2004 12:03 AM
