s2000 clutch buzz cure
Old Oct 20, 2012 | 03:09 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have installed every disc you can imagine. They all buzz except oem. Oem is the only way to go for the disc.
Old Oct 20, 2012 | 04:43 PM
TougeS2k's Avatar
clutch buzz turns me on
Old Oct 20, 2012 | 06:20 PM
s2s3xy's Avatar
ugh 1700 is nuts to replace it im going to have to look elsewhere or maybe another s2000
Old Oct 20, 2012 | 06:40 PM
NDAZONE's Avatar
Originally Posted by s2klariat
Originally Posted by NDAZONE' timestamp='1350749480' post='22096940
Red is correct. Clutch Buzz can be taken care of. Honda did the TSB on my car back in 2000 or '01 and I have not had an issue since. It has to do with needing stronger springs in the clutch disc. An aftermarket one should remedy the issue as well.
This is false. Most aftermarket discs will buzz as well. The new OEM disc is all you need. If you plan having more power down the road I recommend getting an ACT pressure plate and an OEM disc. No buzz, twice the clamping force, and feels relatively stock.
I stand corrected.
I would be quite pissed if I spent good money on an aftermarket clutch to have the same issue.
Old Oct 20, 2012 | 06:43 PM
InTheZone's Avatar
If you can find a tuner shop and not a regular car repair shop you can usually get better rates. Not all are like this, I just never had any knowledgeable person help out working at soandso's car repair or dealership guaranteed to kill your wallet.
A normal price to me would be $750 or less. And depending if you get aftermarket, it may be a little more and you probably have a chance at having more clutch buzz.
Old Oct 20, 2012 | 06:46 PM
s2s3xy's Avatar
that would be a price im willing to live with... Im gonna see if the guy will take the car with me to a honda dealer and get a diagnostic and if the buzz is the only issue this one might be the one... just cant stand that terrible noise
Old Oct 20, 2012 | 07:05 PM
s2cho's Avatar
just turn up the music? lol dont waste 1700 dollars and maybe get the problem fixed. use that money toward something else.
Old Oct 20, 2012 | 07:41 PM
RedY2KS2k's Avatar
Why not just do it yourself and save about 1/2 of that amount?
Old Oct 20, 2012 | 08:35 PM
Si Isnt Enough's Avatar
This
Old Oct 20, 2012 | 11:30 PM
SpitfireS's Avatar
My clutch buzzes like a fridge (actually, its gear backlash in the trans during engine braking... oh well)
My pads squeel like pigs when cold.
My 4.57 diff howls like a wolf.
My winter tires humm like a bumblebee.
A drizzle on the softtop sounds like a waterfall.
Windnoise above 220 km/h (top up) sounds like a hurricane.
Windnoise above 180 km/h (top down AND windows down, don't be a pu$$) is close to deafening.
