S2000 Head/Piston Question
Old Mar 5, 2006 | 03:33 PM
SpiralF20's Avatar
Unhappy
Not really worried bout the rings .. worried about the opinions I got on what I should do honestly I wish I wouldnt have ot do the rings so I can save some money.
Old Mar 5, 2006 | 04:19 PM
pushinlsteg's Avatar
alright lets look at the facts here.
160 psi is bad, reguardless, you should definately be at least in the 200 compression range across the board.
as far as leakdown test results, 5-10% is okay, but 16 is making me wonder.
during the leakdown test, you should of found WHERE it was leaking from. there are a few ways of doing this, listen at your exhaust while the cylinder is under pressure, if you hear air, its your exhaust valves, if its from your intake, it yours intake valves, and the last, if its blowing by your rings, you should be able to pop your dip stick and feel air coming from the hole.
now a blown head gasket...eh, hard to make up for that much loss. it would be more logical if you let us know where the gasket was blown, as far as closer to the side where the 2 cylinders are leaking the worse/have bad compression?
give full details when it comes to these things.
I'm a newer S2k owner but I have alot...and I mean alot of experience with motors and hondas.
good luck
Corey
Old Mar 5, 2006 | 05:41 PM
SpiralF20's Avatar
the head gasket is leaking on the sides near the 2 cylinders and there is some wear on the middle too I could take some pics of it but I am not sure on how to post it
Old Mar 6, 2006 | 01:11 AM
RACER's Avatar
You can post pictures on this site by becoming a member of S2KI.com
click here
Old Mar 6, 2006 | 02:26 AM
SpiralF20's Avatar
Post
okay kool ill see about the sign up but yea soo ill just basically fix that piston ring i guess i got nothing to lose except some money lol thanks for the input guys I really appreciate it Ill fill you in more as I go along
rrounds
Sep 23, 2019 10:18 PM
MB
Jul 29, 2017 11:08 AM
tdfst
Feb 6, 2013 08:52 PM
Jacques79
Aug 20, 2007 12:31 AM
beroznikmal
Jun 13, 2003 12:03 PM
