S2000 JDM Compression Test
Old Oct 18, 2005 | 07:23 AM
  #21
XXX240's Avatar
Thanks Guys...
So, I believe 260 psi in my cylinders is a healthy compression.
Does anyone know exactly what is the compression when the engine is new?
Thanks
Old Oct 18, 2005 | 11:09 AM
  #22
jimknapp's Avatar
Stock spec on an F20C is 225 psi (in the book at least). Your engine sounds VERY healthy at 260 +/- per cylinder.
Old Oct 18, 2005 | 07:29 PM
  #23
jimknapp's Avatar
Actually I took .008" off the head (because I screwed up the radiator plumbing and overheated the thing) and added a set of 14.5:1 pistons and my compression is only 258 psi or so. Maybe I don't really have 14.5's? Sure is a big dome though with huge valve reliefs.
Later,
Jim
Old Oct 19, 2005 | 12:12 PM
  #24
jyeung528's Avatar
interesting
Old Oct 19, 2005 | 03:22 PM
  #25
Trip's Avatar
Later,
Jim
14.5:1
are you running on VP ?
Old Oct 20, 2005 | 06:28 AM
  #26
jimknapp's Avatar
Don't know what VP is, but I'm guessing it's hi test gasoline. Yes, I use I think 110 octane out of the local race gas pump at one of the local stations.
And don't forget, this is a race only application where I basically put my foot into it, let the rev limiter keep the engine together when I shift, and then pull the chute after 96 seconds at full throttle. Also I only run at 3000 and 4200 foot elevations so that lowers the numbers a bit.
BTW does anyone know how to make my avatat look properly proportioned?
Thanks,
Jim
Kane Jacobs
Jul 3, 2018 05:17 AM
motoracer90
Aug 7, 2011 06:23 PM
umair_k
Feb 25, 2008 04:16 AM
Amit
Mar 24, 2006 09:26 AM
north9586
Aug 1, 2003 08:54 AM
