S2k sputtering...jerking/bogging at lower rpms
Old Jun 22, 2010 | 03:08 AM
chillout18's Avatar
Default S2k sputtering...jerking/bogging at lower rpms
Issue started occuring a couple weeks ago. I have a 2000 with about 51k on it. When I start the car it sounds like its sputtering out of the exhaust like its getting to much fuel or something. Also when I start to drive at low RPMs it almost feels like its jerking/bogging between loosing power and driving normal. Feels like maybe the fuels cutting off untill I give it more gas.
Currently I'm all bolts ons and nothing been added or removed to make this happen. I'm guessing could be a bad map sendor, plugs or my Walbro fuel pump is going bad? My map is zipped tied down from a yr or 2 ago when I did the map wack but Ill try the map wack again tonight. No CEL btw
Any other suggestions?
Thanks
Mike
Old Jun 22, 2010 | 04:18 AM
raymo19's Avatar
I'd have a look at the plugs next.
Old Jun 22, 2010 | 11:44 AM
Torqueless's Avatar
sounds like misfiring symptoms
Old Jun 22, 2010 | 12:29 PM
twohoos's Avatar
Look in the misfire thread (top of forum). Unfortunately there's lots of possibilities, all with similar symptoms. Could be MAP sensor (incl. clogged throttle body passage), clogged injector(s), coil pack(s) going bad, and on and on. Could even be ECU.
Good luck!
Old Jun 22, 2010 | 01:07 PM
raymo19's Avatar
That's why I said check the plugs next. They usually have a story to tell. From there you can start swapping coil packs, etc.
Old Jul 13, 2010 | 05:38 AM
chillout18's Avatar
Plugs were black - running rick for some reason. Changed them and it was fine for a day or so them symtoms started to creep up again. Map has been changed and I put my stock fuel pump back in. Symtoms still occuring. If it was a misfire wouldnt I throw a code?
Old Aug 12, 2010 | 03:42 AM
chillout18's Avatar
TTT new plugs are getting dark again...
Old Aug 12, 2010 | 10:48 AM
JDMzimbo's Avatar
Man i have the exact same problem! Its been going on for about 4 months now and i dont know how to fix it. iv got new plugs and coilpacks as well and still no fix
Old Aug 12, 2010 | 11:56 AM
chillout18's Avatar
I know theres a couple people havin this issue on here....injectors,ecu or o2 is all i can think of thats left
Old Aug 14, 2010 | 10:09 PM
davee503's Avatar
Hey, thought Id jump in and offer some advice.....I had the same problem. Car felt like it was stalling, missing, and lacking fuel. No CEL. After changing plugs and MAP, finally replaced primary o2 and that did it. No more problems. Hope this helps
