S2k sputtering...jerking/bogging at lower rpms
Old Aug 15, 2010 | 05:13 AM
eDiesel's Avatar
its very odd that your not getting a cel
Old Aug 15, 2010 | 05:46 AM
s2k16803's Avatar
this sounds like a problem I had when my synapse engineering missing link stopped working... The one way valve inside started letting air go both ways so I got a major vacuum leak right under the map sensor causing my car to run very very very rich... Check ur map sensor and check for vacuum leaks.
Old Aug 23, 2010 | 07:46 AM
chillout18's Avatar
replaced o2 and isuue still occuring
Old Aug 23, 2010 | 10:18 AM
CanuckS2000's Avatar
Do a compression and leak down test. This will give you a idea what's up with the internals. Also tell you if it's likely a electrical or mechanical issue.
Old Aug 23, 2010 | 11:36 AM
Crisgo's Avatar
Did you by chance inspect your valve lash/ valve adjustment? Were you able to check fuel pressure? Still no engine light? Are you running stock ecu? All engine grounds good? When it is idling have you done a engine balance test to see if you are maybe only having this issue the one cylinder instead of all 4. A compression and leakdown may need to be done after the first steps mentioned.
s2k_aristo02
Apr 17, 2018 07:26 PM
I_s2k1
Jun 9, 2013 04:49 PM
Morris
May 22, 2007 03:48 PM
REV_29K
Oct 1, 2005 01:08 AM
nEVERCLEAR
Jul 11, 2002 08:06 AM
