Safe to drill in this part of footwell?
I'm planning to install a small fire extinguisher with a bracket just in front of the passenger seat, in the trough shown here:
On the under-side, it looks like this:
Looks like it's straight through, except for that raised ridge in the middle. I'll try to avoid it, but just in case, is that just to strengthen the metal, or is it some kind of conduit? Assuming the former, but good to check! Also FWIW I know it's a good idea to make a hole in the carpet first before drilling, so the drill bit doesn't catch the carpet. Thanks!
Passenger side is easy. Driver side is gas lines.You're good.
You should check out: https://elementfire.com/
__________________
My For Sale Thread: JDM and OEM parts
> Originating in Italy, Element has been certified in Europe by CE and TUV (in addition to other international certifications). Currently within North America, Underwriters Laboratories (UL) does not yet have a testing standard written from which to certify Element. For this reason Element cannot be used to substitute extinguishers in regulated environments that require a UL (or UL endorsed) certification. Element however can freely be used as a supplemental extinguisher in these environments and as a primary extinguisher where there is no regulation (car, home, personal garage, etc.)
I've got 2 E50's coming for my S2000's. I would email Element @ info@ElementFire.com if you have any questions about their products, the owner is knowledgeable and replies back pretty quickly.
__________________
My only concern with the Element is a under hood fire flares up and out fast when the hood is opened and from the videos I've seen you have to be able to get close to a fire with the Element . Heat rises and I don't know if you could get the smoke(don't know what else to call it) from the Element to the heat source(base of fire) before the heat takes the smoke up, up and away.
ROD
ROD
ROD
ROD
