Safe rev limit
Old Feb 2, 2019 | 06:20 PM
Xeon's Avatar
Default Safe rev limit
Currently tunned on haltech plug and play ecu on my ap1 s2000 what do you guys consider the safe rev limit of the f20c is 9200 ok? Or should I stick to 9000
Old Feb 2, 2019 | 07:48 PM
Slowcrash_101's Avatar
9k fuel cut
Old Feb 3, 2019 | 03:32 PM
Xeon's Avatar
Originally Posted by Slowcrash_101
9k fuel cut
i can’t set a fuel cut and an ignition cut at 2 different rpms I have a soft cut and an ignition cut I set my soft cut to 150rpm before my 9100 rpm ignition cut
Old Feb 3, 2019 | 04:29 PM
zeroptzero's Avatar
the engine starts losing power well before 9000 rpms in stock form, and the engine stays well within the vtec power band in each gear when shifted ahead of 9000 rpm so unless you have some big cams I don't see the need to go 9200. If you can make power right to 9000+ rpms with your engine then go for it, otherwise I don't see the benefit.
Old Feb 3, 2019 | 07:23 PM
Xeon's Avatar
the point is to be able to get that extra time in each gear to avoid shifting on track also because I have a soft rev limit set and a hard rev limit set and I want to have a good gap in between them at least 150rpm so the car starts cutting ignition at 8950 and at 9100 it’s completely cut
Old Feb 3, 2019 | 07:51 PM
Xeon's Avatar
It’s not very clear some people state that the f20c redline is 9200 and some say it’s 9000
Old Feb 4, 2019 | 02:30 AM
Its actually 8,800 red line 9k hard cut.
Old Feb 4, 2019 | 08:02 AM
Xeon's Avatar
thank you this was the information I am trying to attain because some people say it’s 9200 hard cut and 9k redline
Old Feb 4, 2019 | 12:33 PM
vjarnot's Avatar
I'm curious - where are you getting this? It's been over a decade, but I'd have bet serious money my ap1 freely revved past 9k ... commonly accepted wisdom around here used to be approx 9,200 and change for fuel cutoff.
User 121020
Jun 2, 2011 01:56 PM
onepocket
Sep 18, 2006 06:50 PM
Bertin-S2000
Aug 5, 2006 12:58 AM
S2KNJ
Mar 9, 2005 07:41 AM
samjabori
Mar 26, 2004 01:59 PM
