Seating the Valve Cover Properly?
Old Mar 14, 2012 | 10:05 AM
bnag0's Avatar
Originally Posted by JFUSION
I would double check it like mentioned above, the seals look to be too close to the top of the metal tubes, they should have slid down further than that once the valve cover was torqued down, that's what I was referring to in my previous reply.
Are you sure they are suppose to be a waise down the tube? I set the gaskets just like the picture above (left side) this creates the gasket to rid quite a bit higer on the tube almost at the top.... and yes its seated all the way down and tightened... Maybe ill take another shot of it today and try to get a better quality angle.
Old Mar 14, 2012 | 10:42 AM
zeroptzero's Avatar
maybe it was just the picture you posted, they don't ride too much below the rim of the tube but they do go over and down the tube a bit. In your picture it looked like the seal was barely over the top of the tube. When I put my cover on it tents up on the tubes and once I coax the seals over the tubes the valvecover drops a good bit, so I believe the seals shimmy down a bit.
Old Mar 14, 2012 | 12:45 PM
bnag0's Avatar
Gotcha,
Well i pulled my packs quick and gently pushed the seals down a bit so they are like .50"-.75" down past the top of the tube.
Thanks for the advice everyone!
Old Jun 22, 2012 | 06:56 AM
DaGou's Avatar
I want to powder coat my VC. Does any know how to remove the seals and how to put them back in. they looked to be attached to a metal collar that is somehow pushed in. Help! Do I have to go to a dealer for special tool xxxy-yzyzy-zxyz?
Old Jun 22, 2012 | 12:36 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
use a sharp punch and colapse them inwards from the side until they are shaped like pac-man. Then they will come right out.
Old Jun 22, 2012 | 06:17 PM
DaGou's Avatar
Thanks guys, got them out!
Old Jun 22, 2012 | 08:53 PM
boyguan's Avatar
Lube the seals and it will slide smooth
Danwolski
Jul 13, 2015 01:13 PM
blbarretts2k
Sep 2, 2005 09:30 PM
apex2k
Jan 12, 2005 08:15 PM
