shaking when hard braking
Old Sep 11, 2007 | 10:36 PM
fastdriver's Avatar
Default shaking when hard braking
I've noticed when after a few hard laps on the track when I do some late braking there's some noticable shaking seemingly from the engine. Is this normal? This sure never happened with my S14. Appreciate some input, thanks guys!
Old Sep 11, 2007 | 10:42 PM
attack666's Avatar
check your brake pads or drums.
Old Sep 11, 2007 | 10:58 PM
mikegarrison's Avatar
Drums? WTF?
Anyway, shaking under hard braking is most likely a sign of problems with the rotors. Try swapping the rotors out and see if the problem goes away.
Also, what brake pads are you using?
Old Sep 12, 2007 | 01:09 AM
cuonice's Avatar
Possibly melted pad material to rotor? If so have your rotors turned if they are still within spec.
Old Sep 12, 2007 | 01:21 AM
RACER's Avatar
Originally Posted by mikegarrison,Sep 11 2007, 11:58 PM
Drums? WTF?
I've upgraded my rear's to high performance drums.
Old Sep 12, 2007 | 01:23 AM
RACER's Avatar
When you experience the shaking, do you feel vibrations in the brake pedal?
Old Sep 12, 2007 | 01:26 AM
iam7head's Avatar
could be alot of thing.
it could be your pad is cracked from the heavy braking
it could be your caliper is moving/flexing
it coule be your just had some brake fade and the car is struggling to get even distribution of brake torque
Old Sep 12, 2007 | 07:01 AM
gpchaz151's Avatar
warped rotors
Old Sep 12, 2007 | 07:13 AM
RemusPT's Avatar
Originally Posted by gpchaz151,Sep 12 2007, 07:01 AM
warped rotors
Exactly...
Old Sep 12, 2007 | 09:20 AM
chuhsi's Avatar
did you use your ebrake after lapping without proper cooling?
