Shifter Glitch
Old Jun 6, 2005 | 01:44 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I would test fit both bushings to the trans, with out the shifter. Put the small one on the end of a pencil or something and make sure it floats well through the hole in the shift rod.
Same for the large one, in the housing.
Old Jun 7, 2005 | 09:08 AM
ayelien's Avatar
No trick really. they were tight but ulimately just pretty much poped them off by hand.
Old Jun 7, 2005 | 01:43 PM
Billman250's Avatar
Top Answer: 1
If you have as much rust/corrosion as you say, it is likely the bushings are worn. This would explain why you were able to get them off so easily.
Old Jun 10, 2005 | 09:06 AM
ayelien's Avatar
Could be. I'll be taking them apart again this weekend to clean out the corrosion so I'll give you all and update.
K_mann
May 28, 2014 04:47 AM
Jenady
Nov 12, 2007 07:15 AM
nazaracing
Jul 29, 2007 03:31 PM
ayelien
Jun 21, 2004 09:27 PM
